586,033 active members*
3,077 visitors online*
Page 21 of 23 111920212223
Results 401 to 420 of 442
  1. #401
    Jan 2008
    1529
    Re: Designing new Router called Maximus
    Peter,
    Can you post a model / picture that includes only the bits you would be selling? To make it clear what is the DIY bench bit etc.
  2. #402
    Jul 2018
    6339
    Hi Pippin - Here's the parts on offer. I am working on a study set of drawings part by part. If you or others are interested send me a PM requesting dwgs and when done I'll fwd to you. People can buy one part or the lot depending on their needs. Thanks for following the story. Peter
  3. #403
    Jul 2018
    6339
    Hi All- BST Motion have confirmed they can send 20mm rail up to 2.85m. So I shall convert long axis to 20mm rail and cars. The freight company has a 3m max on box length...All good. Peter
  4. #404
    Sep 2019
    197
    Peter...looking good
  5. #405
    Jul 2018
    6339
    Hi All - getting errors trying to reply to posts so this is a test. I set up a random carbon fibre stack today to make a billet. Site is running super slow... anyone else having probs? Peter
    so this thread seems to work!! but so slow!!!
  6. #406
    15362
    Posting seems to be working ok but have had the same problems as you have had at different times it always seems to correct it's self
    Your first block looks good is it structurally as you expected
    How many layers and is this in the middle or spread through out the block
    Mactec54
  7. #407
    Jul 2018
    6339
    Hi Mactec - structurally I expect it to be about 50GPa. Its mainly 300gsm plain weave and some 450gsm double bias. Didn't count layers aimed at 12mm thick. Its 200x400mm which suits the granite block that I'm also testing. I'll either use a caul on top to keep it flat or make a timber frame for its edges. Haven't decided that yet. I'll infuse it then trim and block it. Seems my suppliers have a lot of offcuts so I'll try to stock some sizes or do it to order.
    https://cncrouterkits.com.au/2019/06/28/for-sale/ Cheers Peter S
  8. #408
    15362
    Just got 2 samples in the mail of 3D printed Nylon with chopped carbon fiber and Nylon with continuous carbon fiber very impressed
    The chopped carbon fiber
    Flexural Strength 81 MPa
    Flexural Stiffness 3.6 GPa
    Reinforced with continuous fiber ( this sample is very good you can check them out at Markforged
    Flexural Strength 540MPa
    Flexural Stiffness 51 GPa
    Mactec54
  9. #409
    Jul 2018
    6339
    Hi Mactec - The carbon printing is steadily getting better. Using infusion I build CF parts with 80-90GPa stiffness and 1200MPa strength. I've had a few 3D printed parts quoted and they are expensive for production parts. If someone had the $$$ and was making a one off machine may make sense. But soon ordinary machine shops will be doing it at ordinary rates then it will make really good sense. I am looking at it for making moulds, makes sense to print a mould vs cut it in aluminium nearly. Peter CNCzone still running very slow and getting error 403 on many threads...
    I was looking for stiffness values of hiwin rails/cars and came across this :
    Attached Files Attached Files
  10. #410
    Sep 2019
    197
    Interesting stuff Peter!!
  11. #411
    Jul 2018
    6339
    Hi All - I set up the CF stack to infuse on some granite to test its heat performance. But I decided not to do it as the granite is a bit small which makes the infusion complex. So I started making a moulding table out of a piece of formply I have. A bench 1200x1200mm will be excellent to get the moulded parts (Tetrium and RCFB) moving. Just need some space, need to sell one of my routers!! Peter
  12. #412
    15362
    These guys are already bringing it to the Hobby and commercial level and not really that expensive to do it https://markforged.com/
    Check this for your 403 problem https://www.hostinger.com/tutorials/...-how-to-fix-it
    Mactec54
  13. #413
    Jul 2018
    6339
    Hi Mactec - Yes I have seen their ads for very cheap parts but does not seem to be the case in Oz yet. Thks for info in error 403. Have been thru some of this but no help. Peter
  14. #414
    Jul 2018
    6339
    Hi All - Interesting occurrence. I received a phone call from the first supplier last week apologising for the very slow response on the quotes (Months). They then promptly quoted. The prices are a bit more / less then the second supplier so I shall split the order. The first supplier has equipment that does some things really well that the second supplier does not have. We are now into the Christmas mayhem period. I have had discussions and trial cutting with a chap that makes timber racking. He's very excited about Maximus. He's moving into bigger premises so he can get a full size router so that maybe 2020's first sale. Xmas is taking over many things. Parties, shutdowns and openings, holidays. So all of you have a great Xmas if I don't mention it by then. Ho Ho Ho Peter
    On another matter. I have been working on a new workshop and the plans have been approved by our local council so I can now start to build our new workshop (9mx14m) so march next year I'll have room to build big machines. 2020 I want to build a small 5 axis machine and a big (3mx1.2mx1m Z or bigger) 3 axis machine. Stay tuned. Ho Ho Ho
  15. #415
    Sep 2019
    197
    Sounds exciting...well done
  16. #416
    Jul 2018
    6339
    Hi All - Here's a couple of articles on machine design. One is on damping, the other design. The design article has an area on EG. I like the uni lecture notes, covers a lot of territory. Even has a section on the benefits of lowering the machine mass, that's what I like to hear!! I've put Bamburgs thesis in here as well, always worth another read....Peter
  17. #417
    Jul 2018
    6339
    Hi Everyone - Have a Merry Christmas!!! Peter
  18. #418
    Jul 2018
    6339
    Hello to 2020 - I'm revisiting Maximus to change the rail sizes and have a quick review. I've found a cabinet maker to work with to cut the benches and bases. Waiting on some quotes to see how that goes. I have a company interested in distributing Brevis, so 2020 is looking good. From my day job here's a 4140 shaft I designed coming out of Q&T heat treat... this is a small one for a trailer that carries a 360 tonne truck... Peter
  19. #419
    Jul 2018
    6339
    Hi All - The temperature of the shaft is 600-700deg C which is the same temp as stress relief. So if you get your steel parts thermally SR'ed this is the colour it will be during that process. Very hot. Peter
    https://blog.adafruit.com/2016/06/20...-heated-steel/
  20. #420
    Jun 2010
    4256
    It's when your cutter goes that colour that you know you are really in trouble!
    Cheers
    Roger
  1. Designing a cnc router
    By prodigy86 in forum DIY CNC Router Table Machines
    Last Post: 08-22-2022, 02:54 PM
  2. Probus Maximus
    By 1875 in forum Mach Wizards, Macros, & Addons
    Last Post: 02-16-2016, 03:07 AM
  3. Designing my first 3Axis cnc router, able to cut alu.
    By Pettersen in forum DIY CNC Router Table Machines
    Last Post: 12-19-2015, 08:45 PM
  4. An Aussie Router called RPM
    By bones in forum CNC Wood Router Project Log
    Last Post: 12-02-2008, 04:49 PM
  5. Designing/planning my first cnc router
    By capncrunch in forum CNC Wood Router Project Log
    Last Post: 09-21-2005, 05:48 PM
