586,069 active members*
3,720 visitors online*
Results 1 to 8 of 8
    50w laser engraver
    This is what I get when trying to engraver iv got a 50w laser cutter engraver Chinese one
    Re: 50w laser engraver
    The photo is not clear. Are you saying it's good, or bad?
    Sent from my SM-G935F using Tapatalk
    Quote Originally Posted by TokinSpokane View Post
    Bad its got a pattern on it and it suppose to be smooth
    I have one of these 50 watt lasers also. I'm still not sure if I'm understanding what your problem is. Are you saying it has a deep texture & you want it more smooth? Give as much detail as you can. Are you new to lasers?
    Yes I'm new to laser engraving I would like it to smoother as it is leaving a deep texture we're it has engraved
    Lower your power setting to max 15%. Then set your speed to 50mm per second. Run a test to check the quality. Set the speed higher or lower until you get what you want. Different woods may need different speeds because of density. Try that out and see if it works.
    Engraving problems
    I'll have a go thanks. Also I think the laser is only engraving one direction is that normal?
    Re: Engraving problems
    Quote Originally Posted by craigleon123 View Post
    1st keep the power at 15% & increase the speed to 300mm per second.
    2nd click on "path optimization".
    3rd always run the simulation. It will show you exactly how your image will cut, power, speed, the direction of the laser head movement & the time it will take from start to finish.
  1. gcc c180 laser engraver problem .. laser tube firing a continuous weak beam
    By badrawy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-27-2020, 01:41 AM
  2. 40W co2 laser engraving cutting machine engraver cutter cnc CO2 Laser Engraver Cutter
    By ecpur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 08:23 AM
  3. wklaser (Gweike laser) 2011 No. 1 Hot Product--6040N laser engraver display
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2014, 02:25 PM
