586,070 active members*
3,556 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Buying NEW VFD for 2.2KW Spindle (OLD VFD died)
Page 1 of 2 12
Results 1 to 20 of 91
    Jan 2017
    31
    Ok, this morning my VFD died. YL600-2s-2k20 for 2.2KW spindle. This was bought from a company that said it was able to use 110V. No smoke, no pop, just the slow winding down of the spindle. The display on the VFD had something on it (CN????) but before I could read it, the display went off. Powering off/on did nothing. Connections look good. Power is there. One tiny LED D12 is on, that is all.
    I've had the VFD for about two years.
    So, that brings me to now. I'm looking at some VFDs on Amazon and am looking at 220v models such as:(VFD 220V 3.0KW 4hp Variable Frequency Drive CNC VFD Motor Drive Inverter Converter for Spindle Motor Speed Control HUANYANG HY-Series(3KW, 220V))
    or should I step up to the 4.0KW 5.5 HP?
    Any suggestions?
    If you have a similar setup, I'd like to hear from you as well.
    Thanks!
    Charles
    15362
    Re: Buying NEW VFD for 2.2KW Spindle (OLD VFD died)
    Quote Originally Posted by cduncan64 View Post
    Any suggestions?
    Thanks!
    Charles
    Why where you using 120v it's not the voltage that normally kills a VFD it have the wrong Parameters set that does them some serious damage
    You have to know the spec's for the VFD model there are some that can run on 120v but those that are any good for a 2.2Kw spindle will be 220v/240v
    3kw would be good for the 2.2Kw spindle
    Mactec54
    Jan 2017
    31
    Thank you for the quick response.
    Well, at the time I didn't have a 220v outlet in the shop and since the company I bought my spindle from had a 110v VFD controller for a 2.2KW spindle I went that route. They also posted the parameters that need to be set in order to use the VFD with that spindle.
    Can we post links on the forum?
    Again, thanks.
    Jan 2017
    31
    Do you have any good or bad comments about this VFD?
    https://www.amazon.com/Variable-Freq...ay&sr=8-9&th=1
    Jan 2017
    31
    I'm thinking about that 220v VFD, then I would need a 220v spindle?
    https://www.amazon.com/dp/B077BTW4NQ?th=1
    https://www.amazon.com/Air-cooled-24..._t2_b077btw4nq
    Thanks again.
    Charles
    15362
    Thanks again.
    Charles
    What is wrong with the spindle you have, just test the UVW and Ground pin to see if it is ok
    Pin1 to Pin2=
    Pin2 to Pin3=
    Pin3 to Pin1=
    And Pin 4 to the Spindle Body most are not connected and this will have to be corrected like photo
    Mactec54
    Jun 2013
    43
    I recently bought that same VFD. It's bee n working just fine so far. Easy to set up and has good instruction manual.
    Jan 2017
    31
    @milo30
    Mind if I ask what spindle are you using and are you using mach3?
    Charles
    15362
    That is a low cost VFD and will work very well, a word of caution the wiring has to be correct,and Parameters have to be set correct or the same thing can happen
    Mactec54
    Jun 2013
    43
    A Chinese water cooled 3Kw. No I changed out all the Mach 3 stuff for Centroid Acorn.
    Jan 2017
    31
    Did you get the spindle off Amazon or eBAY?
    Jun 2013
    43
    No, my machine came with the spindle.
    Feb 2019
    15
    Any suggestions?
    Thanks!
    Charles
    Five HP is better,
    15362
    Quote Originally Posted by atocom View Post
    Five HP is better,
    Not for a 2.2Kw Spindle
    Mactec54
    Jan 2017
    31
    mactec54 or anyone else,
    Is there a wiring diagram for wiring the power inside an enclosure?
    I'd like to see what other people have come up with.
    15362
    Ericks has a good example has a lot more in his cabinet than you will need but will give you an idea, if you go through his whole electrical cabinet build
    https://www.cnczone.com/forums/diy-c...nc-cad-25.html
    Mactec54
    Mar 2015
    23
    I am setting up my vfd and spindle using the same components in this thread, 3kw VFD and 2.2 KW spindle. With an input of 220V single phase 25-30 amps how do you connect 10ga wire to the ridiculously small R and T terminals on this drive? Where do you find wire lugs small enough to fit the small terminals but will still work for 10ga wire.
    Jan 2017
    31
    I'll check in the morn.
    15362
    Quote Originally Posted by Rickpt View Post
    There are other suppliers also https://www.ebay.com/itm/10-Pcs-Ring...sAAOSwiYlaJkSB
    Mactec54
    Mar 2015
    23
    Those are just like the ones I have, too big to fit the tiny terminals. I will keep searching they have to be out there somewhere.
    Hard to believe those tiny M3 screw terminals can handle 30 amps.
Page 1 of 2 12
  1. Buying new Chinese ATC spindle.
    By 520052 in forum Chinese Machines
    Last Post: 05-12-2020, 05:42 PM
  2. Buying a VFD Spindle
    By basha318i in forum Spindles / VFD
    Last Post: 04-05-2018, 09:41 PM
  3. Replies: 16
    Last Post: 09-23-2015, 11:54 PM
  4. X3 spindle motor died - Any easy retrofit solutions?
    By pumpercloggs in forum Syil Products
    Last Post: 02-16-2014, 10:25 PM
  5. Replies: 8
    Last Post: 11-21-2013, 06:53 PM
