586,301 active members*
4,046 visitors online*
    Jul 2010
    Mazatrol T1 Initialization Procedure
    I have the parameters but not the procedure to initialize and clear the T1 control before re-entering them.
    Would appreciate any help.
    Jul 2010
    62
    How to clear asterisks on T1. You will need to take note of parameters first.
    to clear all rubbush on T1
    Press MENU key. Press Param. press PAGE, bring cursor to OP12, press
    111111118 IMPUT
    Power off/on
    To clear tool data
    Press MENU key
    Press T-Data
    Press 8th button from left
    press CLEAR key
    To clear "Tool set"
    Press menu key
    Press T-SET
    Press 9th key from left
    Press CLEAR key
    To clear cutting conditions
    Press MENU key
    Press C-COND
    Press 9th button from left
    Press CLEAR key
    To clear "Programme"
    Press MENU
    press PROG
    press ALL ERASE
    press INPUT
    To clear parameters
    press MENU key
    press PARAM
    press 8th button from left
    press CLEAR key
    press PAGE menu
    press 8th key
    press CLEAR key
    To load all information
    bring cursor to A7
    press 16 then INPUT to set baud rate
    bring cursor to OP2 and press
    000000101 then INPUT (to set CMT available
    Power off/on
    If you have CMT or micro disk or Griffo with info on it, connect to machine.
    Press MENU
    press DATA IN OUT
    press DATA IN
    press 123456
    press INPUT
    the CMT will load all information
    otherwise you will have to load it manually.
    to load parameters OP1/16, there are 8 digits 0 or 1, if there are 2 "1" on line type 2 as 9th digit etc
  1. Replies: 9
    Last Post: 08-20-2018, 03:57 PM
  2. Weeke 12, tool changer initialization procedure
    By viesitis in forum Commercial CNC Wood Routers
    Last Post: 04-04-2011, 09:34 AM
  3. mazatrol m32 starting procedure
    By zavateandu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-28-2010, 11:05 AM
  4. Mazatrol T1 Setup Procedure
    By mattme in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2007, 07:24 AM
  5. Mazatrol M-1 - Initial procedure
    By lecamtu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2005, 04:22 PM
