586,395 active members*
2,733 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Home and Limit Switch Recommendations
Results 1 to 18 of 18
    I'm looking for recommendations on relatively inexpensive Home and limit switches for a DIY build. If possible I would like to use 3 limit switches also as Home switches. Then 3 less expensive/precise switches for the opposite end of stroke. What are you using that works well?
    Dec 2013
    5717
    Re: Home and Limit Switch Recommendations
    I have used these successfully for precision positioning (+/- 0.0005 inch). Requires a little fiddling with the ramp on the operating cam to get that repeatability, needs to be about a 90° edge with almost no radius so you get an instant snap over..
    https://www.ebay.com/itm/10pcs-V-156...frcectupt=true
    Can't get much cheaper than that.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2005
    222
    I used these. Pretty much the same as Jim used.
    https://www.sparkfun.com/products/13119
    Mount them so you can either adjust the ramp or the switch.
    You don't have issues shearing the roller off or the arm bending over time?
    Dec 2013
    5717
    Quote Originally Posted by Project_Hopeless View Post
    You have to set the arm in exactly the correct position, so the cam hits a couple thousandths forward of the roller C/L. You also have a very small radius on the cam. Like I said, it's a little fiddly, but it works. Or you can buy a $60 precision limit switch.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2009
    744
    I actually used ones similar to those mechanical switches on my old machine but without rollers to eliminate any play/deterioration in the roller.
    Working fine for over seven years but you should try to mount them with the arm facing down so that dust/debris doesn't pile up on the joint.
    Had to clean junk off the arm once in a while.
    Dec 2003
    1228
    Quote Originally Posted by davida1234 View Post
    Now that is quality advice!I am not too far from doing this sort of thing myself and I hadn't even considered this aspect.Thank you.
    Oct 2009
    744
    Very welcome....
    1943
    I personally like the inductive proximity switches for limits and homing switches. They are very accurate, about 0.0002" from my testing, and have been very reliable on my machines. They are non-contact and just require a metallic target, which can be part of the machine or an added target.
    https://youtu.be/IGO47l62T2o
    Quote Originally Posted by 109jb View Post
    I'm surprised you get that accuracy from a prox! The ones I'm familar with on conveyors are no where near that accurate.
    I worry with a prox setup if something is slightly out of wack and the axis drifts it could smash into the prox. How far is the metal target to the prox when it trips?
    Oct 2009
    744
    They do seem to be about as accurate as the mechanical switches.
    You don't have to arrange them such that the metal hits the prox.
    Usually, the metal needs to come close like 4-8mm to prox.
    It could just pass underneath.
    Mechanicals are definitely easier to set up and don't need
    a power source. They can also be arranged in series which
    works better. It's more complicated to do that with e-switches
    if at all possible.
    Do you get the same repeatability if the target passes underneath vs. approaching head on?
    Oct 2009
    744
    I don't know, never risked it that way.
    But I can imagine that you need to be closer with passing by vs. approaching.
    Nov 2012
    1267
    Still, I personally don't like relying on a switch for long-term repeatability. Mechanical switches wear over time; proximity sensors may change sensitivity with voltage, temperature etc. The traditional approach - switch+encoder - seems more robust.
    May 2005
    3920
    I think the important thing to understand here is that there is no perfect solution. For Example Micro Switch type switches of the type linked to above can be very good up until you get crap or swarf in the lever mechanism. Prox switches are great unless you are machining metallics that the switches can trigger off. In a lot of the machinery I work on axis limits are either mechanical switches with enclosed mechanisms or prox switches. Homing on these is a different issue because home is refined off the zero pulse (servos).
    While a precise rehome can be beneficial it might not be worth the trouble. It is pretty common in the CNC milling world to probe the part (sometimes the fixture) before machining. That may or may not be useful for a router machine and the work you do. What I’m m getting at here is that if you go cheap with limit switches homing accuracy might not be a big deal. Say you are doing sheet goods, if the home position is off by a couple of thousands does it really matter if you are cutting parts out of a 4x8 panel.
    Another thing worth considering is plunger style micro switches. That is switches that delete the lever arm for a plunger. The primary advantage here is the lack of a lever arm to bend or get cruded up. These require a bit more thinking when it comes to mounting though you can get plunger type switches with rollers.
    Also if you want to get real cheap with the electronics/switches you can use a single switch with a long cam. That long cam though is usually more work that it is worth. However you can design in the “cam” at design time. You also loose the ability to know which direction faulted if your controller supports it. You also loose the ability to move the CAM or switch if you are in chicken mode with a new fixture.
    Cool Re: Home and Limit Switch Recommendations
    Quote Originally Posted by wizard View Post
    That is my situation exactly. If I get 1/100 inch ,0.25mm or better repeatablity that will be more than adequate for my needs.
    1943
    Was on vacation for a few days, but will try to address some of the questions that came up about my prox switch use.
    1. The video I linked was really just a hack together for testing. I later made things much neater, but it showed the general arrangement I used on that machine which is approaching the target head on.
    2. I have also used the prox switches with a target that passes the sensor from the side in a slide-by arrangement. I find this arrangement to be just as accurate and there isn't a possibility of crashing into the prox sensor because the target can't come into contact when set up this way. I did similar testing to what is shown in the linked video, and the repeatability seems to be as good as the head-on arrangement. Thinking about it, you could probably set up some kind of wiper arrangement to sweep off the target to tackle the swarf issues.
    3. In regard to potentially crashing the target into the sensor, I still have the machine I used in the video with the head-on target and have never had it happen. This is a small machine and it decelerates quickly enough that it hasn't been a problem, but using the slide-by arrangement solves this.
    4. Swarf can be an issue with false triggering, but the same is true for any switch. On the machine in the video, I would up putting the X-axis prox sensor and target under the table where swarf has not been an issue. For the Y-axis, I built a guard that keeps the swarf off, and the Z axis sensor is up high enough that it can't easily get swarf on it..
    5. Accuracy of the prox switches is great, but as pointed out, how good you need is dependent on what you are doing. My machine that I linked the video to is a milling machine and not a router. For my use, I need high accuracy for cases where I want to shut the machine down, and then resume the job another time. I want the homing of the machine to be very close so that once homed it is ready to load a program and go., The prox switches provide high enough accuracy for my needs. Is it the best? No. As pointed out earlier a setup that uses a switch to get close and an encoder index to fine tune is the best, but not many people need that kind of accuracy and in the case of that machine in the video is open loop so the encoder index isn't there anyway. The +-0.0002" I have been able to get with just the prox switches is fine for me. Whether you need that much accuracy is up to you, but personally I see no reason to not put on accurate switches, be they prox, mechanical, optical, or whatever because the cost difference between a switch that isn't accurate and one that is isn't much. One of the reasons I do like the prox switches is because they are very accurate and also very inexpensive.
    6. As far as prox sensor accuracy being affected by temp, voltage, etc. OK, I'll concede this as a possibility, but we are talking about pretty small changes in the sensitivity and even this is dependent on the particular user situation. My prox sensors are connected to a regulated power supply so there will be very little voltage change to worry about. As for the temperature, in the past I researched this and at least for my use, the temperature effects were going to be negligible. The change in sensing distance with temperature goes from about +10% at -13 deg F to -10% at 140 deg F. This is about 0.065% of the sensing distance per degree temperature change. My shop is always within about 20 degrees whether summer or winter, so that equates to a maximum change due to temperature of about 0.001". Again, it depends on your use, but that is fine for me.
    May 2005
    3920
    Personally I’d go with a roller plunger type switch. Something like: https://www.automationdirect.com/adc...yABEgJ28PD_BwE. Note that the price is rather high but you can get something molar switches from China pretty cheap. Such switches are fairly resistant to damage and crude and thus are good in exposed areas. Save the micro switch lever arm units for protected areas. A decent switch should repeat reliably to within a few thousands.
    While not cheap as you wanted such switches will likely be problem free for years.
  1. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
  2. limit switch- home switch
    By normd in forum CamSoft Products
    Last Post: 05-17-2008, 12:56 AM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
