586,061 active members*
4,673 visitors online*
Thread: G03 issue
    May 2013
    62
    G03 issue
    HI All,
    I have an odd issue when cutting circles (waterjet) using G03. Sometimes it just does the pierce but does not cut the circle.
    Playing with some test code I get the following odd behavior:
    Works:
    G00 x2.15 y10.4789
    G03 x2.15 y10.4789 i0.0 j0.65 f20.0
    Does not work:
    G00 x2.16 y10.4789
    G03 x2.16 y10.4789 i0.0 j0.65 f20.0
    Less than .15 works more than .16 on the x does not work. WTF?
    This is running using the Kflop motion controller if that matters.
    Cheers
    Chris
    Re: G03 issue
    WHat are your steps/unit on the X axis?
    I've heard that there's a bug if the steps/unit setting is too course, circles can get skipped.
    Not sure that's the issue, but sounds like it might be.
  1. Replies: 2
    Last Post: 08-25-2017, 07:55 PM
  2. Incoming Power Issue, or Transistor Issue
    By barchdesigns in forum CNC Machine Related Electronics
    Last Post: 08-19-2016, 10:32 PM
  3. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  4. Replies: 1
    Last Post: 01-08-2016, 06:58 AM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
