586,069 active members*
3,847 visitors online*
    Aug 2007
    138
    Powering a large mill with a VFD
    I have a large CNC mill that wants 3 phase 220 volts at 21 kw
    anyone power somthing like this with a single to three phase variable frequency drive?
    I can pick up a 20 kw on for around a thousand
    Dec 2013
    5717
    Re: Powering a large mill with a VFD
    For something that size you really want a rotary phase converter or maybe a solid state converter like a Phase Perfect. A VFD won't work to generate 3 phase to run the machine. And to operate a VFD on single phase, you need to upsize the VFD by at least about 1.7 or 2x. So something around 35-40 KW output.
    Do you have enough single phase 240V power available? You're going to need around 100 amps or more to run that machine at full power.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Quote Originally Posted by Dancy View Post
    You can't run anything other that a AC spindle motor with a VFD Drive, it can not be used to supply power to anything else, they don't output the same sinewave as normal power supply it would be great if they could everyone would be using them
    Your only chance to run a machine that size is with a Phase Perfect first choice or a CNC rated Rotary Phase Converter RPC which is some case's is also not suitable for some CNC Machines
    Mactec54
    Feb 2019
    15
    single phase to 3 phase converter is comfortable,
  1. How large a Face mill diameter on a VF-2SS?
    By amasters in forum Haas Mills
    Last Post: 11-29-2018, 06:10 AM
  2. Large jig mill cnc help needed.
    By drumsticksplint in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2013, 08:44 PM
  3. Stepper for large mill ???
    By Guido72 in forum Stepper Motors / Drives
    Last Post: 01-13-2008, 08:13 PM
  4. Cutting a piece to large for my mill
    By BeerFizz in forum OneCNC
    Last Post: 05-10-2007, 09:47 PM
  5. How large steppers do I need on a Taig mill??
    By jaru-eri in forum Taig Mills / Lathes
    Last Post: 07-29-2006, 01:34 PM
