586,035 active members*
3,889 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco VMX 40 axis problem
    Nov 2018
    6
    Jun 2008
    1104
    Re: Hurco VMX 40 axis problem
    Have a look at the Y axis Servopack to see if the display is jumping around.
    Jan 2017
    23
    1. First i take off belt to see that it runs without belt, but make marking.
    2. If servo runs without then problem in mechanics if not then problem in servo side.
    3. Servo side need to take of and check for problems.
    4. SERVO if ok for mechaniks it posible the wire is broken and you can ckeck with tester for wire problem.
    P.s i have wire broke problem
    Išsi?sta naudojantis SM-G960F Tapatalk 4 Lt
    Hurco BMC 2416
  1. problem in my hurco vm1 please help
    By hondasniper in forum HURCO
    Last Post: 12-04-2017, 03:17 AM
  2. Hurco BMC-30 -- RPM problem
    By ergxx in forum HURCO
    Last Post: 03-18-2014, 03:48 PM
  3. G42 Hurco problem
    By macca5 in forum HURCO
    Last Post: 04-01-2013, 06:12 PM
  4. Hurco ATC arm Problem
    By mpi in forum HURCO
    Last Post: 06-29-2009, 01:13 PM
