586,655 active members*
2,451 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > CHNC1 Turret Encoder wiring?
    Aug 2010
    75
    FIXED IT!!!!! I pulled the cover off to check some voltages and one of the wires was unplugged. 6 wires come from the encoder. TB9-4,5,6,7,8 are all still hooked up. 5 out of the 6 wires are accounted for and I don't know where the black wire goes, Any and all help is appreciated I found an image from a different post but my wires don't match his pinout so I haven't tried it. What I do know is 5red,6oj,7yellow,8green are signal wires 4brownPos. and TB11-9blackNeg.
    TB11-9 black Neg
    TB9-4 brown Pos
    TB9-5 red Signal
    TB9-6 oj Signal
    TB9-7 yellow Signal
    TB9-8 green Signal
    Mar 2010
    1852
    Re: CHNC1 Turret Encoder wiring?
    Hope this helps!
    Mike
    P.S.: rereading it I guess it may not. Don't have time to pull covers right now, maybe later.
    Aug 2010
    75
    No need to pull your cover. Thanks for the quick response. I got it squared away. The machine is working great again.
    Mar 2010
    1852
    Good to hear---------
    Feb 2010
    84
    Quote Originally Posted by Machineit View Post
    Hope this helps!
    Mike
    Hi Machineit, do you have more of the diagrams for the CHNC2? Does it go more in depth inside the encoder itself by chance?
  1. turret servo/encoder question
    By redman_80us in forum Fanuc
    Last Post: 06-28-2018, 05:25 PM
  2. Takisawa TC1 turret encoder connection
    By Doctorie in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2013, 11:52 AM
  3. TURRET ENCODER
    By egral in forum Fanuc
    Last Post: 07-07-2011, 08:25 AM
  4. HT20 TURRET ENCODER PROBLEM
    Last Post: 06-24-2011, 05:12 AM
  5. turret encoder
    By Karl_T in forum CamSoft Products
    Last Post: 12-08-2005, 07:09 PM
