586,094 active members*
3,709 visitors online*
    Jul 2014
    67
    waterjet for granite cutting
    Hello.
    I have an 6 axis robot and i want to add water jet cutting option to the robot.
    What i need to buy for cutting granite slabs up to 3cm or up to 6cm thick ?
    Thanks.
    Sep 2011
    110
    Re: waterjet for granite cutting
    It seems a very dangerous idea, and robot is with far lower precision
    Normal 2D waterjet is enough to cut the granite slabs material.
    Feb 2009
    6028
    Is your robot waterproof? Dustproof? Strong enough to handle 20K psi+ ? Do you have an area that can support a huge mess? Waterjets are cool, but most people don't realize what kind of support equipment needed, the mess they generate, and the consumables. So, you would need a water tank to place the granite on, a supply pump to feed the booster pump, multiple filter systems, custom made high pressure lines and a garnet feed system (may not be required on granite) and a hardened nozzle to start with.
    Sep 2011
    110
    Quote Originally Posted by underthetire View Post
    Couldn't agree more
    Jul 2014
    67
    Robot is kuka 180kg payload so it has enough power for waterjet.
    Repeatability is 0.1mm that is enough for me.
    Please see this video https://www.youtube.com/watch?v=qQ-76VCxs6I
    The cuts i want need 6 axis 3 axis are not enough..
    All the support equipment exists there is a marble processing factory.
    What equipment want for waterjet cutting granite 2cm & 3cm think with good speed ?
  1. Wild Idea - Cutting granite.....
    By racedirector in forum DIY CNC Router Table Machines
    Last Post: 07-02-2012, 06:46 AM
  2. Waterjet cutting machine promotion of JETE WATERJET
    By livemott in forum News Announcements
    Last Post: 09-25-2011, 03:25 PM
  3. Newb Looking to Get CNC setup for cutting granite
    By denversash in forum Want To Buy...Need help!
    Last Post: 08-09-2011, 04:27 AM
  4. Granite cutting
    By MBG in forum Community Club House
    Last Post: 02-25-2008, 03:24 AM
  5. Waterjet vs Intermac (granite)
    By nonnsgranite in forum Waterjet General Topics
    Last Post: 08-03-2006, 07:31 PM
