586,105 active members*
3,313 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Copy and change tool offset using user task
Results 1 to 19 of 19
    Jan 2010
    171
    Hello
    We usually use a CAM software for Programming and it's easier to use nose comp at 0 instead of the radius of the mill.
    The problem here is With OSP-U100L we can't use a negative value on comp.
    So i wan't to Call for example tool 50 copy the offset put them to offset 200 then add the radius value from cam, how would something like this look like?
    I know how on Fanuc but user task is New to me.
    Jun 2015
    4154
    Re: Copy and change tool offset using user task
    hello protozyko short answer : do you have the VNSR* available on your machine ? go mdi , input V1=VNSRX[01] and V2=VNSRZ[01], and check if the results are the Xrad[1] and Zrad[1]; if those variables are there, i may help you with "negative radius"; if that system variable does not work, then stop generating the code with r0, but with r=tool_nose_r
    there are toolpaths:
    ... generated directly on nose radius center, aka "virtual toolpaths"
    ... with real part dimensions + g41/g42, aka classical "comp toolpaths"
    compensation codes should handle :
    ... lead-in movement :,when tool moves from a "non-comp position" to the "1st comp position", or the approach
    ... lead-out movement : when the tool moves from "last comp position" to a "non-comp position", or the depart
    ....... about the lead-in movement, on a lathe, considering that turret is at home, is possible to approach directly into comp-position, thus to remove the auxialary movements when compensation is started; for osp 300 " T+LINK*10101 M66 G97 S+V1 M42 M03 M08 G00 X2*13.25 Z-3 M63 F+V2 G95 G41 K-1 M65 "; now lets simplify this for an older " G00 X2*13.25 Z-3 G41 K-1 "
    ... imaginary vectors, so to be able to keep always same absolut clearance, regardless of radius value : for example, if nose-rad is 2mm or 0.05mm, in both cases, same code can be used in order to keep the z position constant " G00 X Z G42 I/K vectors "
    ... auxialary movements, when geometrical elements inside the toolpath are not tangent; from this perspective, a "virtual toolpath" may be optimized, because such auxialary movement can be inspected before running the code, while a "classical comp toolpath" requires to run the code and inspect the cnc output; however, it may be possible that the motion generated by the cnc is better then the motion generated by the cam
    i shared all these aspects, tring to highlight some particularities of comp codes ... a code generated with all those within should perform faster, with at least few tens of a second
    so the easiest way, is ... hmm, do you know that book about becaming a cnc programmer in 24 hours ? just kidding
    radius value is not alone; there are 3 inputs : Xrad, Zrad and P_comp_quad
    X&Z radius may be equal<>0, only one 0, both 0, thus there are 3 cases
    for each case, may be used at least on P, so the diversity appears
    this combo, for lathes, is not designed to use negative radius, is not designed for "virtual toolpaths", but only for "classical comp toolpaths"
    so, if you use "virtual toolpaths", you may hit a wall
    ... but there may be a solution for you, and this solution involves system variables; pls check the availability of VNSRX [ 01 ] and VNSRZ [ 01 ] for your machine; those variables should return the Xrad and Zrad for radius_register_1
    a few things based on those variables, and some differences between cam & cnc outputs are covered in here : https://www.cnczone.com/forums/okuma/320382-cnc.html
    kindly
    Jan 2010
    171
    VNSRX[200]=VNSRX[V1] is what i needed.
    Jun 2015
    4154
    hello protozyko vnsr* works on your system ?
    VNSRX [ 200 ] = VNSRX [ V1 ] is what i needed
    if you wish to achieve an effect, like after inputing a negative radius, i am afraid that is not enough to copy-paste the radius why don't you generate the toolpath with r=tool_nose_r, so to avoid the case of 'negative radius' ?
    Jan 2010
    171
    Quote Originally Posted by deadlykitten View Post
    From CAM i output the radius of the tool so V2=5(radius) VNSRX[200]=VNSRX[V1]+V2 will do what i need.
    Jun 2015
    4154
    i use those system variables, so to set data directly from program, so to avoid pushing keystrokes at the panel; for example, for an od tool, with nose_r=0.8, i use VNSRX [ 01 ] = 0.8 VNSRZ [ 01 ] = 0.8 VNRPN [ 01 ] = 3
    output from cam VNSRX [ arg ] = 5 VNSRZ [ arg ] = 5 and VNRPN [ arg ] = P_quadrant
    that's all i don't see why you go through V200, V2, etc .... even if it works, it is too much ... why do you copy the offset ?
    Jan 2010
    171
    I copy and change the offset, in my tool. For example if i have -0,06 in tool 14, i copy it to 200 and add the nose radius for example 4 wich gives me 3.94 in compensation.
    Jun 2015
    4154
    corections can be made in " main offset " , " wear " , " radius "
    in most cases, only one is used if i get it right, you take the value from " wear " and copy it inside the " radius "; thus, if you have wear -0.06, then you wish to modify the radius from 4 to 3.94 ? why do you update the radius ? why don't you modify the radius directly ? there is something that i don't understand ...
    is this a lathe or a mill ? and if it is a lathe, why do you use T14 ? is there an atc ? or is a turret with more then 12 posts ? is this about a turning or a milling operation ? what tool is there ? i am lost
    how do you know that you have -0.06 in T14 ? i am asking, because i can't understand exactly what you are doing
    Jan 2010
    171
    Machine is lathe With milling spindle. i have 200 Tools so i don't have wear offset page.
    Nose radius should be 0 to keep it simple but we need to correct small amounts from time to time.
    My problem is fixed for now anyway.
    Jun 2015
    4154
    i really don't understand why you don't edit the radius directly, and i still don't see how ( if ) you managed the negative radius case ?
    if you have 200tools and 12 turret posts, then ... hmm ... i don't know / kindly
    Jan 2010
    171
    I do edit the radius, but i program With tool center not tool edge, so if there is radius 5 in tool page for 10.mm mill the part will be 5.mm wrong, and if i program With tool edge and i forget to put in the 5 the part will be 5.mm wrong, so we keep it 0.
    I don't have turret i have a milling spindle.
    Jun 2015
    4154
    ok, and if you edit the radius, why don't you edit directly ? why do edit it like this " V2=5(radius) VNSRX[200]=VNSRX[V1]+V2 " ? who is 200 ( i suppose your active tool ) and who is V1 ? why do use V1 ?
    i believed that you have a turret with milling spindle; in other words, you have a multitasking machine ?
    if you program on tool center, but tool_radius_offset is <> 0, then simply don't call the radius inside the program ( at least when roughing ); so, whatever the radius value inside the register, your program will ignore it
    if you call the radius inside the program, and you wish to be sure, then check it's value :
    Code:
        IF [ VNSRX [ 01 ] EQ 5 ] NJUMP1
                 NLOOP1 M0 ( wrong radius value )
                 GOTO NLOOP1
        NJUMP1 NOEX
        IF [ VNSRZ [ 01 ] EQ 5 ] NJUMP2
                 NLOOP2 M0 ( wrong radius value )
                 GOTO NLOOP2
        NJUMP2 NOEX
    if you wish to apply ±0.2 corections on that radius, then you can check it like this :
    Code:
        IF [ ABS [ VNSRX [ 01 ] - 5 ] LE 0.2 ] NJUMP1
                 GOTO NLOOP1
        NJUMP1 NOEX
        IF [ ABS [ VNSRZ [ 01 ] - 5 ] LE 0.2 ] NJUMP2
                 GOTO NLOOP2
        NJUMP2 NOEX
    kindly
    Jan 2010
    171
    200 is a tool offset i use for calculated offset. V1 is a variable i need for the radius
    Looks like it.
    If only my mills where 0 all the time
    Code:
                 GOTO NLOOP1
        NJUMP1 NOEX
                 GOTO NLOOP2
        NJUMP2 NOEX
    Code:
                 GOTO NLOOP1
        NJUMP1 NOEX
                 GOTO NLOOP2
        NJUMP2 NOEX
    kindly
    Or i can do it way so i don't get any alarm and all radius comp is kept around 0
    Jun 2015
    4154
    hello again
    why ? i really don't understand why you manage it like that ... pls, can you explain it a bit more ?
    how can you do that ?
    Jan 2010
    171
    hello again
    I don't a wear, so i use offset kinda like a wear.
    This is how i can keep radius around 0.
    Jun 2015
    4154
    aha ... ok, so you use a "main offset" like a "wear field", and that value you transmit inside the "radius"
    but, if you wish to modify with 0.1, why don't you modify the radius directly ? why don't you go into radius, and push add +0.1 ? why do you use another variable ? maybe you wish to avoid the case when, instead of using 'add' ( final result radius=5.1 ), maybe is used 'set' ( final result radius=0.1 )
    Jan 2010
    171
    Because i want them to be around 0, and negative value doesn't work on okuma, it will read it as a positive number.
    Jun 2015
    4154
    ahamz, ok .... if you work with rad=5, and input small corections ±k, it will be arround 5±k, thus it will always be positive, because 5-k will always be >0
    i believe that you will never get out of 5
    ±0.3; is it ok so far ?
    Jun 2015
    4154
    hello again
    output from CAM "NOEX VNSRX [ active_tool ] = 5 + VNSRX [ 01 ] ", and, like this, you remove v1 & v2
    another method, is to use " VNSRX [ active_tool ] = 5 " only once, before starting to make parts, so to avoid the time required to set the radius at the panel; this is kind of a "pressetting-program"; like this, you remove VNSRX[v1] and the time required to push keystrokes, so to set the radius in the end, input corections directly into vnsrx[200], so stop using vnsrx[1], and, inside the program, check if vnsrx[200] is between 4.7 - 5.3, so to add safety
    like this, set-up time will be lowered, and long-term operation will be checked for operator inputs
    whatever you do, in the end, VNSRX [ 200 ] will always be positive
    my point, is that you can implement negative radius behaviour, inside the controller : use a conditional code inside the program, that changes G41 & G42, accordingly to operator input; on compensation codes, i can use " set -0.3 enter " inside secondary offsets, and code will adapt
    this method requires code customization ( kind of a pretty capable post ), and a software capable to deliver that customization / kindly
  1. WHILE and User Task 3
    By rdhoggattjr in forum Okuma
    Last Post: 10-31-2015, 05:21 PM
  2. User task 2
    By Shopgeek in forum Okuma
    Last Post: 05-05-2015, 10:26 PM
  3. User task and User task 2
    By shags72 in forum Parametric Programing
    Last Post: 12-23-2013, 05:55 PM
  4. Okuma User Task II G,F,M Status
    By calgarykevvy in forum Okuma
    Last Post: 07-09-2009, 04:02 PM
  5. Okuma's User Task 2
    By compuslave in forum G-Code Programing
    Last Post: 02-29-2008, 01:36 AM
