586,036 active members*
3,523 visitors online*
IndustryArena Forum > CAM Software > Vectric > Z cutting deeper the more time goes by ???
Page 6 of 6 456
Results 101 to 105 of 105
  1. #101
    Apr 2016
    841
    Re: Z cutting deeper the more time goes by ???
    Quote Originally Posted by RCaffin View Post
    This is a standard test.
    Set up a Dial Indicator on the table and put a square-ended bit of metal in the spindle.
    Lower the spindle until you have a reading on the DI.
    Now cycle the Z axis up and down 50 times and see if and how the DI creeps.
    If it suddenly jumps - um, interesting.
    But if it just creeps steadily, then you are picking up or losing Z axis Step pulses on every direction change.
    Cheers
    Roger
    Roger,
    He tried 20 up/down cycles each at 15 IPM, 30 IPM and 60 IPM (60 cycles total). I have attached what the OP prepared showing the results. An increase of .0005" on the down stroke in the 10th cycle at 30 IPM is a bit odd, but it remained constant for the last 10 cycles. I'm not sure I would consider it a significant anomaly, since is consistent for the other 40 cycles, and it's only .0005". I'm guessing that the .0005" change had more to do with the dial indicator than with the machine. I have one that has .0005" resolution, but it's not accurate to .0005".
    Do these results meet your suggestion , or do you endorse giving it another go, only doing 50 continuous cycles at a fixed velocity? Do you have a velocity recommendation? As noted, when the problem showed up, he was running Z at only 5 IPM. Maybe he should run at that speed to simulate what happened during actual production?
    Gary
  2. #102
    Apr 2016
    841
    When the Z axis stalls while retracting, or lifting, it ends up lower than it's supposed to be. So the next move down will be deeper.
    Forehead slapping senior moment. It's the same effect as a slipping coupling attached to the screw. I'm embarrassed that it wasn't obvious to me. It should have been. Thank you for getting me back on track.
    Gary
  3. #103
    Jun 2010
    4256
    Hi Gary
    That data says to me that it is NOT an electronics problem (as I had previously suggested).
    Cheers
    Roger
  4. #104
    That's not a good test for lost steps.
    Lost steps on the Z axis will typically happen with lots of rapid, back and forth random movements, like 3D carving.
  5. #105
    Aug 2009
    1573
    No News ....This might help if, you tweek Z axis Motor
    https://www.machsupport.com/wp-conte...all_Config.pdf
    Page 77 of 106 pdf
    or
    5.5.2 Motor Tuning and Setup ..page 5-19
    Good Luck,
    DJ
Page 6 of 6 456
  1. LAser cutting machine makes a wave in a corner at the time of cutting
    By angeldp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2017, 03:51 PM
  2. Machine cutting deeper than G code indicates
    By kaetamer in forum Avid CNC
    Last Post: 12-12-2016, 11:30 PM
  3. Z axis cutting deeper than expected
    By bitsa in forum Chinese Machines
    Last Post: 11-08-2015, 08:40 AM
  4. Cutting deeper than flute length
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 12-22-2011, 04:49 AM
  5. Cutting deeper than cutting length
    By magudaman in forum CNC Tooling
    Last Post: 10-10-2011, 04:36 AM
