586,068 active members*
3,899 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Boosting voltage between drivers and motors
    Aug 2017
    34
    I currently use an all-in-one controller for my CNC router that I absolutely love with one exception: it limits my input voltage to 36V. Since it's self-contained, the control signals are converted to motion signals by the drivers internally, preventing me from using external drivers and a larger power supply.
    Is it possible to boost the voltage going to the motors AFTER the controller with a boost converter? Would it have adverse effects on the controller given its 36-volt limit?
    Alternatively, is there a way to translate/convert the motion signals coming out of the controller back to control signals, as they were before they reached the drivers? That would let me use my own drivers/power supply. The controller does not have external control-signal outputs.
    Dec 2013
    5717
    Re: Boosting voltage between drivers and motors
    A follower amplifier is really what you want, but the odds of one actually working in that application are slim. Not to mention the development time involved in building a device like this, then of course you need one for each channel of each motor.
    It might be a lot easier to break out the step & direction signals from the controller and use external drives.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2017
    34
    I'd thought of this but as it's all on one integrated PCB I don't see how it could be done.
    Dec 2013
    5717
    Quote Originally Posted by retrosmith View Post
    It would require looking at the data sheets for the driver chips and find which pins are the step & direction signals. Then tap into those. I think you would be looking for the CLK and CW/CCW pins. This would require some electronics experience, and some test equipment.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2017
    34
    Appreciate the info. Sadly, I don't think I love this controller quite that much. I'll either find some more efficient motors or switch controllers.
  1. Low Voltage vs High Voltage Stepper motors?
    By Brian_M in forum Stepper Motors / Drives
    Last Post: 06-21-2017, 07:29 PM
  2. Replies: 4
    Last Post: 03-29-2017, 01:59 AM
  3. High voltage (180 VDC) spindle drivers?
    By RCaffin in forum Spindles / VFD
    Last Post: 09-20-2014, 03:44 PM
  4. Stepper motor&drivers,servo motors&drivers,motion control card CHINA factory
    By stepmotordriver in forum Manufacture Company Listing
    Last Post: 06-21-2014, 09:14 AM
  5. Boosting PWM voltage, suggestions
    By DaveDoesIT in forum CNC Machine Related Electronics
    Last Post: 09-26-2008, 02:42 PM
