586,114 active members*
3,279 visitors online*
    Mar 2019
    mach3 working abnormal
    Hi to all..
    Would like to know please if anyone experienced what I am. When I run Mach3 and toolpath or even just a spindle run Mach 3 goes bananas. I am connected to my cnc 900x1500 via MKx-IV mach3 motion card with usb cable. I can see applications starting up on their own, such as the calculator, or mail box, and can see that the +, - and arrow keys are activating themselves like as being pressed from the keyboard. This happens when my cnc is on. In offline wont happen.
    What is the mysterious thing???!! To tell all the the story I disconnected x,y and z cables, connect them again, changed the usb cable and worked perfectly, after 1 day it's doing it again, back to square 1. I reinstalled mach 3 several times, virus free, even changed the computer.
    Any help please or and idea what could causing this?
    Thanks!!
    15362
    Re: mach3 working abnormal
    Quote Originally Posted by MarioDjynn View Post
    Hi to all..
    Thanks!!
    What are you using for a spindle sounds like you have a wiring problem
    Mactec54
    Mar 2016
    44
    Hi to all..
    Thanks!!
    It is most likely going to be something with you motion card, Mach3 is a printer port soft Ware. Your motion card is simulating a printer port. So I would investigate from that motion card, it sounds like you are picking up interference from something.
    Sent from my Nexus 6 using Tapatalk
  1. Mach3 z axis goto zero not working
    By Inkable in forum Mach Software (ArtSoft software)
    Last Post: 10-29-2015, 04:13 AM
  2. Spindle not working under mach3 via USB
    By mik_m in forum Uncategorised WoodWorking Machines
    Last Post: 12-14-2013, 03:16 AM
  3. Mach3 R3.043.022 not working
    By scotty001 in forum Mach Mill
    Last Post: 06-16-2011, 08:43 PM
  4. THC300 not working using Mach3
    By Bobbyr70 in forum Mach Plasma / Laser
    Last Post: 11-24-2010, 09:03 PM
  5. Mach2 to Mach3 not working......
    By Normsthename in forum Mach Mill
    Last Post: 01-23-2007, 08:34 PM
