586,036 active members*
3,484 visitors online*
    Question Cable Shielding
    I will end up with slightly long cable runs on a 4x4ft. XYZ router table. My question is with stepper motors, AC powered router, do all cables need to be shielded? (motor, limits, router) If not which ones can you get away with un-shielded?
    15362
    Re: Cable Shielding
    Quote Originally Posted by Project_Hopeless View Post
    For a new install you want to do everything, but Grounding and shield Grounding is important how this is done determines how successful it will be
    Attached Thumbnails Attached Thumbnails Ground Star Point.PNG   Ground Bus.jpg
    Mactec54
    Re: Cable Shielding
    Limit switches also . Can a pair of switches use the same shielded wire for example the +X/-X limits wired with 3-20awg sharing a common ground/source?
    15362
    Re: Cable Shielding
    Sure they can you normally use twisted pairs for any of the low voltage wires, low voltage sometimes have to use a isolated Common, and not connected to High voltage main Star Ground, as high frequency noise on the main Ground can cause problem on low voltage Commons
    Cat6 Shielded cable has even been used for limit switch wire, just a hint
    Mactec54
    Jun 2017
    369
    Re: Cable Shielding
    The least expensive shielded wire I was able to find was from CNC ROUTER PARTS they have them listed with their kits but I'm sure you could purchase them separately. I used to have an old diy table that had many issues and one was I was getting interference so I started looking for shielded wire found it there & ended up purchasing a 4896 pro kit from them
  1. Cable shielding
    By jim_cliff11 in forum Servo Motors / Drives
    Last Post: 01-22-2017, 03:11 AM
  2. Cable shielding. Copper or aluminum?
    By jaru-eri in forum Open Source CNC Machine Designs
    Last Post: 11-14-2012, 12:49 AM
  3. Ok to groud LED's with shielding ?
    By Jackal66 in forum CNC Machine Related Electronics
    Last Post: 07-22-2011, 12:57 AM
  4. EMI shielding
    By bigalow in forum CNC Machine Related Electronics
    Last Post: 02-29-2008, 03:18 PM
  5. Use of shielding gas on wood....
    By sntlewis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-13-2007, 10:06 PM
