586,069 active members*
3,389 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Fiber Laser Cutting Topics > Which fiber laser will do this kind of job?
    I have access to a 100 watt fiber laser and was wondering if I need something different? If I can use this laser to etch these designs what setting would I need to get down to bare metal and in how many passes? and yes I know that the lasers will be a fraction of the speed of this $100k+ laser and Im fine with that. The metal is Carbon Steel (stainless in some cases) and the coating is just black/iron oxide (which i believe is equivalent to rust). Links below:
    https://www.instagram.com/p/BcgObqAD...on_share_sheet
    https://www.instagram.com/p/Bf_85eIn...on_share_sheet
    May 2018
    35
    Re: Which fiber laser will do this kind of job?
    Fiber laser can do the coated materials very well.100w is a little strong you can use 20% power and test with different speed.It's pretty easy.
  1. Which fiber laser will do this kind of job?
    By SterlingNiko in forum Fiber Laser Cutting Topics
    Last Post: 03-26-2019, 11:13 PM
  2. Fiber Laser Engraver, Fiber Marking Machine
    By automationtechinc in forum Automation Technology Products
    Last Post: 07-18-2018, 10:39 PM
  3. cheaper kind steel laser cutter , fiber cutting or co2 ?
    By laserliu in forum Fiber Laser Cutting Topics
    Last Post: 02-17-2017, 08:06 AM
  4. AK10F- A Portable Fiber Laser Marking Machine for Plastic, Fiber and Metal Engineerin
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-29-2016, 05:35 PM
  5. What kind of Laser
    By Herbertkabi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-23-2009, 10:14 PM
