586,465 active members*
3,844 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Building Touch Probe and Toolsetter...
Results 1 to 10 of 10
    Sep 2005
    221
    I previously have posted regarding this topic and got quite a few good suggestions as to the way to go. It appears the Renishaw style use an infrared transmitter, however several people have suggested useing an radio
    transmitter to send out the signal.
    Al_the_man, if you are out there, you mentioned you might have circuits somewhere for a simple transmitter/receiver?
    Is anyone aware of a transmitter/reciever that could be purchased off the shelf and incorporated into a probe?
    By the way, I found a commercially available switch with 1 micron repeatability for around $180 that could be used in both a probe and tool setter.
    Mar 2006
    113
    Can you post a like of the tool setter?
    Dan
    Sep 2005
    221
    pictures of probes and tool setters
    see attached for some pictures, there are other types alsoe i.e. laser non contact tool setters, but most probes look very similar...
    Attached Thumbnails Attached Thumbnails probe1.jpg   probe2.jpg   probe3.jpg   ts2.jpg
    Mar 2006
    113
    I'm sorry I type to fast - I meant can you post the links.
    Dan
    Jul 2003
    1754
    I am using a microswitch as a tool length setter. (I like to mill circuit boards and I don't have a quick change tooling.)
    I have found that the cheap microswitch that I mounted on the table gives me +/-.0003" repeatability. More that accurite enough for me. I have not actually used it in a g-code program yet - but I am can't wait.
    sam
    Dec 2003
    24223
    Quote Originally Posted by REVCAM_Bob View Post
    I did post it before but here is the link http://www.rentron.com/remote.htm I have used some of the RC products and there is also IR circuits.
    Al.
    Albert E.
    Sep 2005
    221
    Thanks Al, I will check it out...
    Sep 2005
    221
    Rentron RF circuits
    I checked out the Rentron site, and ended up calling them up. They told
    me there product would have about a 20 to 30 milisecond trigger time, and
    after doing some calculations, this would require an immensely slow feedrate
    i.e. if moveing 20 inches per minute, the probe would move 0.6 inches in 30 milliseconds. The Galil board I am useing claims to have a high speed latch
    function that can detect encoder position in .1 micro second....
    So I need an rf circuit, if possible, that is much faster than the 20-30 miliseconds optimally 1 millisecond or even better .1 millisecond. It is possibly
    to do some workaround if these speeds are not realistic.
    Is this speed reasonable with a custom encoder?
    Any thoughts?
    May 2004
    82
    "i.e. if moveing 20 inches per minute, the probe would move 0.6 inches in 30 milliseconds."
    If you do the math on this then you are only going to move 0.009999 inch in 30 millisec or ????.
    Bent
    Sep 2005
    221
    Yes you are correct...
    Yes you are right, I forgot to translate the 20" per minute into speed/second.
    This brings the time frame for the probing into a little more realistic range.
    Does anyone know how to tweak these Rentron send/recieve circuits to get
    faster response times? The guy at rentron said something about writeing your
    own decoder?
    If I can find someone that can do it, I would be willing to pay for the help....
  1. homemade 3D touch probe?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 03-09-2021, 02:58 PM
  2. Who want to make a touch probe?
    By MrBean in forum Digitizing and Laser Digitizing
    Last Post: 07-14-2015, 12:28 AM
  3. Probe and toolsetter suggestions?
    By REVCAM_Bob in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2008, 01:12 AM
  4. Z axis touch probe
    By Swede in forum FlashCut CNC
    Last Post: 08-29-2007, 06:09 PM
  5. Pop-up tool touch probe
    By dmealer in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2005, 12:47 PM
