586,485 active members*
2,511 visitors online*
    Mar 2006
    48
    DXF to G Code Converter
    Is there such a thing as a DXF converter to G code converter? I want to take DXF files from our engineers and be able to convert it to G code so that I can edit it and move things around. I don't really want to edit it as a DXF file on the Haas itself. We make heat exchangers here and these are tube hole patterns. Just X and Y locations. Usually 300 to 500 holes in a pattern. I currently use a old DOS program that was created for making patterns and would give me all the hole locations in X and Y. but that setup is on it's last leg and I'm looking for another way to do this.
    thanks for any help.
    Dec 2013
    5717
    Re: DXF to G Code Converter
    Yes, it is very available. It's called a CAM (Computer Aided Manufacturing) program. Look at Fusion 360 by AutoDesk, full professional CAD/CAM package, free to hobbyists, startups, and educators/students, inexpensive for established shops. Another very simple option is CamBam. Either of these programs will allow editing a DXF file, but the CamBam drawing editor is a bit clunky.
    You really want to bring the DXF into a drafting (CAD) program, then process with the CAM program to generate the G code.
    EDIT: What is it that you are needing to move around in G code? Are you actually modifying the engineered hole locations?
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2003
    205
    Our KipwareM will read the DXF file ... you don't even have to load it into anything ... and grab every POINT location as a hole position.
    It will then display a conversational ( fill in the blank ) form where you can input the hole machining parameters ... speed, feed, type of cycle, peck depth etc. etc. ... and will then auto-create the G code program.
    Sounds like it might be exactly what you are looking for ... here's the link :
    https://www.kentechinc.com/kipwarem.html
    Here is a little more specific blog post link :
    New Enhanced Drilling and Milling Features for KipwareM® | The Kipware Blog
    Thank you ...
    63
    I expect every CAD/CAM software will open up Autocad's DXF and DWG files. Mastercam certainly does. But you have to do the grunt work of creating the g-code as it will not automatically do it.
    [email protected]
    http://www.xenomechanics.com
  1. G-code to DXF Converter
    By fst14me in forum Want To Buy...Need help!
    Last Post: 04-08-2013, 05:36 PM
  2. g code converter
    By chrispare in forum G-Code Programing
    Last Post: 08-12-2009, 10:51 AM
  3. 3D dxf to g code converter
    By gaanes in forum Uncategorised CAM Discussion
    Last Post: 06-01-2009, 02:11 PM
  4. Looking for a .dxf to G-Code converter...
    By sciontim in forum OpenSource Software
    Last Post: 06-03-2008, 06:30 PM
  5. Ace Converter G-code Question
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-22-2004, 06:18 PM
