Re: OT I've been a bit busy with other things.
Originally Posted by
The Engine Guy
James
Does you HAAS have the programable coolant nozzles that point the coolant to the end of each tool no matter what the length, if so if memory serves right I did hear somewhere that there should be a built in delay in the control where the nozzles are set to the tools that can be toggled on/off/set, don`t know the age/level of your control so if yours is an early one it may not have that facility or I may have got it all wrong and it was a different make of machine !! (Playing the "age card" here
Regards
Greetings Rob! I have the programmable coolant on a few of machines, I'll try to check that out tomorrow. It is painfully slow and you can hear the pump "dead head" when it comes on if it has been sitting for a while. There is a setting that will delay movement until the spindle comes up to speed, it makes sense there may be a coolant delay as well. Good thinking and hello!
Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
