586,110 active members*
3,392 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Bosch Colt 1hp palm router...spindle equivalent?
Results 1 to 10 of 10
    Oct 2007
    446
    Question Bosch Colt 1hp palm router...spindle equivalent?
    currently running the colt router...was wondering if anyone has knowledge of a spindle equivalent in weight and power, etc.
    Don't want to put anything too much heavier than whats currently on there.
    Advice?
    thx
    15362
    Re: Bosch Colt 1hp palm router...spindle equivalent?
    Quote Originally Posted by airbrush View Post
    Advice?
    thx
    That would be around an 800w spindle and VFD to match the VFD Drive would be most likely a 1.5Kw or you may find one that is 120v single phase input and 220v output that would be ideal and the spindle would be 220v 800w
    Mactec54
    Oct 2007
    446
    ok thanks....weight on those would be somewhat equivalent too??
    specs say 3.3 lbs on it...for the colt
    looks like spindles 800watt are around double the weight ...
    35538
    Looks like they weight about 2.5Kg.
    Oct 2007
    446
    yah....looks like i'll have to stick with the colt for now... was just thinking about down the line...but that would require a new machine for me...or at least rebuilding the gantry...it has unsupported rails on the top gantry ...too much flex in it... bought the machine kit before i knew more about cnc rigidity etc....
    Dec 2014
    640
    I'm kind of in the same boat...I have the Makita RTC0701C as a spindle. With the exception of hurricane force winds coming out of the bottom of it blowing chips everywhere, it's been great. I've had it at least 5 years and recently looked at the brushes...still lots of brush left. I was impressed. I can't think of much of a reason to 'upgrade' to a VFD controlled spindle.
    Oct 2007
    446
    well noise and running longer cut times....i don't do that often but there's been a few times it been running almost 2hrs straight on a 3d finish pass
    guess i'll wait til the bearings explode..ha
    Dec 2014
    640
    I understand...mine's noisy too. I did a job where I 3D machined a guitar neck...took about two hours if I remember correctly. I worried about the router until I looked at the brushes and they're in fine shape. If it does fail, I can buy new one for under $100 from Home Depot.
    Oct 2007
    446
    wasnt worried about brushes....bearings more than anything....but yah, can just replace reasonably cheap and easy when the time comes...
    Sep 2005
    1740
    I ran my Hitachi router, can't think of the model number but it was under $150, it was over a 8 hour job and no issues. Mine ran very quiet and it also had a five year warranty. I have since went to a spindle with more power but that router did ok.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  1. Bosch Colt is dead. Need a new router... Help
    By tatinc2000 in forum DIY CNC Router Table Machines
    Last Post: 10-05-2015, 02:04 AM
  2. bosch colt 1hp variable speed router
    By airbrush in forum DIY CNC Router Table Machines
    Last Post: 04-08-2015, 05:22 PM
  3. Colt Bosch Spindle
    By John Bear Ross in forum Taig Mills / Lathes
    Last Post: 02-08-2010, 06:30 PM
  4. Colt™ Variable-speed Palm Router Kit
    By justCNCit in forum DIY CNC Router Table Machines
    Last Post: 02-16-2009, 07:14 AM
  5. Bosch Palm Router
    By phantomcow2 in forum DIY CNC Router Table Machines
    Last Post: 05-27-2007, 01:09 AM
