586,655 active members*
2,952 visitors online*
    Apr 2006
    512
    mm on startup?
    I have used Imperial ACME rod for my machine and used inches to set up in motor turning. How can I get mach3 to default to mm on the DROs when starting up rather than typing G21?
    Also for squaring slaved motors x and a, is it standard practice to use the Homing offsets?
    Just set up the machine in mm. You can use two different configurations, one for inches and one for mm's.
    Or, try putting G21 in the initialization string in Config>General Config
    Apr 2006
    512
    Thanks Gerry. Put it in string.
  1. Startup Problem
    By StormWerkz in forum Fadal
    Last Post: 03-07-2007, 04:57 AM
  2. V2XT Software Startup
    By cncnavy in forum Bridgeport / Hardinge Mills
    Last Post: 02-17-2007, 11:31 PM
  3. oi-mc startup screen
    By jamesweed in forum Fanuc
    Last Post: 02-09-2007, 05:58 PM
  4. Hurco BMC 20 startup problem
    By tirebiter in forum DNC Problems and Solutions
    Last Post: 11-08-2006, 11:50 PM
  5. Need some startup advices...
    By b_cybe in forum DIY CNC Router Table Machines
    Last Post: 03-16-2006, 11:18 PM
