586,075 active members*
4,186 visitors online*
Results 1 to 8 of 8
    Jun 2010
    86
    What battery?
    Hi all
    I have a electronic memory board (sinumerik 850m CNC machine) that don't have battery and capacitor and I don't have any information about the battery and capacitor but fortunately I found a picture in the internet from this board with battery and capacitor but he quality of photo is low
    Would you please look at the picture (attached picture) and let me know if you know any informations about the battery and capacitor?
    Please help me to know
    Mar 2007
    2083
    Re: What battery?
    the sinumerik 850m CNC machine is not a machine I have worked on
    it could be a tagged version coin cell like a CR2032
    pdf cr2032 data
    Attachment 416434
    tagged CR2032
Name:	tagged cr2032.jpg
    https://www.ebay.co.uk/itm/NEW-3v-Ba...kAAMXQUmFShRWh
    if it was a CR2032 the 20 is the diameter in mm and the 32 is the thicknes in mm (3.2) without the decimal point
    to give you 20mm dia x 3.2 mm thick
    does that look correct when looking at the space on the PCB ?
    It is possible the battery is a rechargeable battery like the VL2330 that has the tags to be soldered to a PCB
    John
    Aug 2009
    1573
    Re: What battery?
    Mod i fry as needed.. 3volts ni-cad?
    Mar 2007
    2083
    Re: What battery?
    going by the photo in post 1
    the EVE ER32L100 looks closer to the original
    pdf data
    ER32L100 data.pdf
    Attachment 416444
    https://www.rapidonline.com/eve-er32...232544-59-6102
    in the past the only memory backup ni cad batteries I have sceen looked like this
    Attachment 416446
    https://cpc.farnell.com/gp-batteries...-6v/dp/BT01325
    note-
    to use a nicad or rechargeable lithium battery the memory card will have to incorporate a charging circuit
    primary cells like the EVE ER32L100 must not be recharged
    John
    Aug 2009
    1573
    Re: What battery?
    china battery's...? maga
    Jun 2010
    86
    Re: What battery?
    Thank you so much John.
    This is a great help.
    Jun 2010
    86
    Hi again
    Sorry for replay again.
    I found another picture that have better qaulity (please see attached picture).
    https://picclick.com/Siemens-Sinumerik-Memory-Card-6FX1818-0BX01-570-262-900101-173262421094.html
    Yes, you are right and it is a nonrechargeable battery.
    Tadiran 3.6V litioum - inorganic battery - TL 5134
    Yes, Mr John: the space on the memory board for this batter is 32mm diameter with 10mm height.
    But would you please let me about the thing that I indicate in the second picture?
    Would you please let me know more about it with detail information?
    I am not an electronic engineer(sorry for simple question).
    I need your help.
    Thank you for your time.
    Mar 2007
    2083
    Re: What battery?
    it looks like a transistor in a TO-5 size encapsulation
    if it is an NPN transistor its possible its a BFY50 or something similar
    its a pity you can not read the part number in the photo
    John
  1. 2100 NCK ALARM 810D - NEED TO CHANGE BATTERY - WHERE IS THE BATTERY LOCATED?
    By scottbryce in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-22-2021, 07:35 AM
  2. Best quality lithium carbonate battery grade supplier and battery grade dealer
    By elitechbio in forum Uncategorised CAM Discussion
    Last Post: 12-12-2018, 09:12 AM
  3. VF-4 battery
    By ktmflyer in forum Haas Mills
    Last Post: 08-18-2015, 04:01 AM
  4. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  5. Replies: 2
    Last Post: 11-07-2013, 04:34 AM
