586,096 active members*
3,113 visitors online*
IndustryArena Forum > CAM Software > MadCAM > 4th axis is not rotating continuously
    Aug 2010
    24
    Hi
    I need help in writing a post for my 4th axis indexing table (Chuck). I am programming in Unigraphics NX8 and tried the generic 4th axis UG post. But the 4th axis is trying to go back to zero before start rotating again. Is there any thing I can change in my post to make the 4th axis run continuously without going back to zero again after each rotation of 360 deg. Can any one send me an example of the post. My 4th axis is set parallel to X axis.
    Any help in this matter will be much appreciated.
    Parm
    Oct 2009
    96
    Re: 4th axis is not rotating continuously
    pcreek,
    Not totally sure that this is what you want.
    View JPG below to see how to set 4 Axis Simultaneous,
    Regards,
    Mauri.
    Aug 2010
    24
    Thank you Mauri
    but I am looking the post processor setting in Unigraphics NX8
    Dec 2008
    3109
    This may be a machine setting....try programming different scenarios to get the machine correct before modifying your CAM
    Oct 2009
    96
    pcreek,
    I left out another setting see Pic below.
    Click on Option then Advanced Settings (hammer&spanner) then make the setting as I have them.
    This should do the continuous rotation for you.
    Regards,
    Mauri.
  1. Rotating axis positioning
    By gtsolid in forum G-Code Programing
    Last Post: 10-03-2018, 04:03 PM
  2. Replies: 8
    Last Post: 08-14-2017, 10:29 AM
  3. Rotating tool around its own axis.
    By Great-Dragon in forum Mechanical Calculations/Engineering Design
    Last Post: 07-04-2014, 10:17 PM
  4. Replies: 2
    Last Post: 05-21-2010, 08:08 AM
  5. Rotating part along the z-axis
    By shneek in forum Mastercam
    Last Post: 04-11-2009, 01:33 AM
