586,108 active members*
3,038 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Tools User Guide for newbie
    Dec 2017
    15
    Hi all.
    it's few months I'm starting to use my homemade cnc, untill now just test jobs.
    Basically, I wish to use it to mill wood, plastic and PCBs.
    I got some bits to make my jobs, but honestly I got them just by.....sensation, meaning: i need to make such a job, maybe this bit can do it for me....
    But searching the web, I can find a lot of kind of bits; the most of them I can't figure out about their use, and maybe some of them can be more usefull to my project than the ones I'm currently using.
    I.e. : performing some milling test for PCB, I'm using a vbit 0.1 mm * 10°. But the results are very poor, mostly because the bit seems to to get wore out very quickly (and I'm testing a PCB 20*30mm); as in my next future plans I should mill some PCB 100*200 mm, if the bit is so problematic that will be really a problem to me.....
    Coming back to the topic, is there such...a "guide to the CNC bit", where you can find a description of the bits and their use?
    Andrea
    Aug 2009
    1573
    Re: Tools User Guide for newbie
    More reading for you about some basic fundamentals of CNC milling, drilling, etc.
    https://en.wikipedia.org/wiki/Speeds_and_feeds
    PCB Machining...Carbide Tools is your friend for longer tool life
    https://en.wikipedia.org/wiki/Printe..._board_milling
    https://en.wikipedia.org/wiki/Printe...board#Drilling
    Good Luck on the your Adventure,
    DJ
    Dec 2017
    15
    Quote Originally Posted by machinehop5 View Post
    DJ
    Thankyou very much for the links
    May 2019
    DJ
    Thanks a lots. I have found it.
    Panasonic Sensor
    https://cambienpanasonic.000webhostapp.com/
  1. TEK10 User Guide?
    By HotRodTractor in forum CNC Machine Related Electronics
    Last Post: 11-01-2016, 02:04 PM
  2. Guide to build CNC with less tools, but it written by Newbie.
    By iD2 in forum DIY CNC Router Table Machines
    Last Post: 11-19-2013, 04:39 PM
  3. sheetcam TNG user guide
    By tig-racer in forum SheetCam
    Last Post: 05-31-2011, 07:49 PM
  4. V11 User Guide released today
    By scadvice in forum Uncategorised CAD Discussion
    Last Post: 02-04-2009, 03:57 AM
  5. Philips 432 user guide
    By koerner in forum Philips
    Last Post: 05-23-2008, 09:22 PM
