586,033 active members*
3,532 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > CNC with vacuum advice needed
    Nov 2011
    9
    Hello,
    I have a CNC machine with a vacuum table of 120x250cm. I use MDF 10mm or 15mm, when I surface the sheet to get a flat surface the MDF sheet curvas outwards. Is this normal? what am I doing wrong?
    Re: CNC with vacuum advice needed
    Yes, it's normal.
    Surface both sides.
    Nov 2011
    9
    Thanks Gerry, will try.
    once you surface it a couple times it happens as well. I find that once it starts to curl on the corners surface it and then flip it over and use the other side and its good for a little while again. that's on a 4'x8' mdf sheet
