586,069 active members*
3,484 visitors online*
IndustryArena Forum > CAM Software > CamBam > CamBam help for Slot
    Dec 2011
    63
    Hello! I have 144 pieces of 1" ID 3/16" wall aluminum tube I have to make "slots" in.... kind of like 1/2 of an oval. I can't figure a way to make the oval, and what to use as a starting point. Everything else I do has a corner to reference as a start point. I've attached a rough drawing of the part. I'll be using a 1/4" Dia. single flute end mill.
    Dec 2013
    5717
    Re: CamBam help for Slot
    Are you doing the drawing in CamBam? You do have a corner to start from, the top right (0,0) point on the drawing. The slot C/L is 0.6875 from that corner and the center of the arc is 0.3125 from the right side.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2012
    1267
    Just draw a C-shaped line and make a profile operation from it.
    Draw a 0.5" circle, add two straight lines, then CTRL-A (select all), CTRL-B (break at intersections), delete one half of the circle, CTRL-A, CTRL-J (join lines). Something like this (see attachment).
    Attached Files Attached Files
  1. How to slot a rectangular slot with convex bottom ?
    By bbwilliamson in forum Mach Mill
    Last Post: 04-19-2016, 12:25 AM
  2. Can CAMBAM do this:
    By cstmwrks in forum CamBam
    Last Post: 03-10-2015, 08:55 PM
  3. one slot is coded other slot is not there
    By cwaugs in forum Uncategorised CAM Discussion
    Last Post: 05-06-2011, 03:00 AM
  4. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  5. Replies: 7
    Last Post: 04-12-2007, 03:00 AM
