586,069 active members*
3,425 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Many chips specification for Multus
Results 1 to 10 of 10
    Aug 2011
    419
    Hi
    What is the meaning of Many chips spec for Multus machines?
    and what is the difference between MANY CHIPS TOOL , MANY CHIPS 4, MANY CHIPS 8 and MANY CHIPS 12 ?
    Which spec should I buy if I want to use triple axial holder?
    Thanks.
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    Re: Many chips specification for Multus
    hi kurmay, i don't have a multus, but isn't there an orientation g-code ? or is it possible to change the encoder origin, or some zero shift, from code ? there should be a parameter for that, and maybe you can acces it from code, so to avoid the special function / kindly
    Aug 2011
    419
    Can anyone share program samples for multi edge cutting tools?
    May 2015
    15
    Kurmay, I cant yet but as soon as I get the option for multiple cutting edges I will.
    Quote Originally Posted by kurmay View Post
    I have the same triple holder but haven't registered it into the tool library yet... However, I do have a twin 80/55 tool that I use daily and it rocks! To properly register it so that it works with cas is a little tricky but doable. Instead of tool register, choose the button right next to it that says MCHP-TL register. Getting the models lined up and positioned correctly takes some playing with. I had to input and register both tools separately and choose their orientation based off this pic I'm attaching. To call up the 80 degree rougher I type TD=07030101 M323 and the 55 finisher is TD=01030101 M323. First 2 numbers are tool edge position, next 2 are turret position, then last 4 are actual tool number. So my edge positions for the twin tool are 1 and 7
    Pic of turret positions.
    I forgot to include that I'm on a u4000 with p300sa control...
    Aug 2011
    419
    How can i use tool nose radius compendation function for higher than 96 tool.
    This sample format is
    TL=05210210 BT=0 M602
    05 is tool index position
    210 is the tool/offset number
    where is nose radius?
    Aug 2011
    419
    is possible to use TNRC when many chip active?
    Jun 2015
    4154
    hy kurmay, T* ( L D S ) may execute different arguments; try this :
    Code:
     type 1 : T* ee rr tt oo ; 2 2 2 2 ; edge radius turret_station offset
     type 2 : T* ee ttt lll  ; 2 3 3   ; l : r+o, thus a combined link, somehow similar to vetf*
    difference between those 2 types, may be based on how many sets of tool compensation are there : 32 ( standard ), 64, 96, 200, 999 ...
    seems you have more then 200 sets; in such a case, only ' type 2 ' may be available for your machine, considering that the ' optional data spec 200+ sets ' was installed ' normally '
    for more infos, maybe you should check ' section s t and m functions ', inside the programing manual
    may be similar to the multi-tool spec, for radial turrets; i don't have a multus, but look a bit inside the the programing/special functions manuals; there should also be a copy inside the machine hdd; if you share those, i will take a look
    not sure about this, but may be the limit of how many ' ee ' sets are available inside the T* comand, thus if you have a tool with 3 edges, you may need ' many chips 4 ' ? also, maybe is possible to avoid this extra function, only by using wise the T comand : for example, i don't have the multi-tool function, but if i would put a tool with 3 edges, on a radial turret, on post 1, i would use T010101 T210121 and T130113
    also, another thing, may be the limit for tool life management ( tool group, tool offset group, etc ) : for example, with 'many chips 4', maybe you are not allowed to declare more then 4 entities in a single management group
    but, to use tool life management, you need to fix 1st the way your T comand works
    kindly
    Jun 2015
    4154
    oh, i just had a simpler idea, that does not involve so much digging :
    ... put something in the M spindle, just to have it clamped
    ... mdi T89123456 ( try no repetitive patern, for example different digits ), v1 = veton, v2 = vetln, and maybe v3 = vetlp
    v1 and v2 should tell you how the T comand works / kindly
    ps :
    ... veton :
    offset number of active tool
    ... vetln : tool number of active tool ( turret/station index ) ( TN00 )
    ... vetlp : current used edge number ( Multi-edge Tool Index Opt., Mac/Mult )
  1. Need some rectangular chips cut to replace CF chips that are cracking
    By Lens4Hire in forum Employment Opportunity
    Last Post: 03-14-2014, 04:47 PM
  2. Scrap value quesiton, chips vs chunks. Coolant mixed with chips?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2013, 12:08 AM
  3. fanuc 11m specification
    By zoeper in forum Fanuc
    Last Post: 07-04-2012, 04:54 PM
  4. Cook your chips to make more chips :)
    By ToMMY2ooo in forum Bending, Forging, Extrusion...
    Last Post: 09-07-2004, 07:38 PM
