586,068 active members*
3,848 visitors online*
    Aug 2004
    210
    How to stop rounded corners in Mach 4 ???
    Hi Everyone
    I am having a hard time here, my projected tool patch has sharp corners but when i run the program it rounds them off.
    I changed Motion Mode to Exact Stop from Constant Velocity, it fixed the problem but the machine now runs super slow in the
    radius or rounder parts of the program.
    Thanks in advance
    Biggs
    Re: How to stop rounded corners in Mach 4 ???
    1) Increase acceleration.
    2) Create toolpaths that "roll around" the corner, leaving your part square.
    3) I think there's a CV wizard to setup the CV controls.
    Nov 2013
    4373
    the rule is that you ensure that your machine is tuned for the highest reliable (no lost steps) acceleration consistent with the rigidity of
    the machine. Best acceleration allow the spindle to follow the tool path more closely.
    Craig
  1. Rounded corners still problematic after switch to exact stop over 89 degrees
    By killersoundz in forum Mach Software (ArtSoft software)
    Last Post: 02-06-2018, 01:09 PM
  2. rounded corners when pcb milling
    By jpm000001 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-09-2012, 08:38 PM
  3. square corners getting rounded off
    By SatanKlawz in forum Uncategorised CAM Discussion
    Last Post: 06-30-2010, 02:33 AM
  4. rounded corners
    By jc286006 in forum Uncategorised CAM Discussion
    Last Post: 06-25-2006, 06:04 PM
  5. Rounded corners...
    By saturnnights in forum SheetCam
    Last Post: 02-13-2006, 08:06 PM
