586,645 active members*
2,674 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma lb 15 osp 5000L-G Software
Results 1 to 10 of 10
    Apr 2015
    45
    Hello, we are struggling now witch okuma lb 15 osp 5000l-g machine, we have bubble memory error and we think that we need to reload software and parameters, we have 8 inch floppy disk with parameters, but we don't have floppy disk reader in the machine, the question if we get smaller floppy drive with parameters from okuma distributors, will we be able to plug it to our machine? And maybe there is a way to send parameters through RS32 cable? Because i know that from cable is possible to send parameters to computer and before we was sending programs from computer to machine using this cable.
    Feb 2009
    6028
    Re: Okuma lb 15 osp 5000L-G Software
    The floppy set for the LB15 requires not only the floppy drive, but also has a interface board that has to slide in to the OSP rack. It's not just parameters, once the bubble goes, you have to reload system files, so no you can't load those through RS232. If you have a bubble error, 95% chance you will need to purchase the replacement SRAM board to replace the bubble card, along with the battery that will now be required for the SRAM. Bubble has not been produced for many years now..
    Apr 2015
    45
    Thank you for your help i appreciate that, we would like to know more about SRAM BOARD, maybe you can post a link for that board from ebay or just picture. The second question is the connections is the same as bubble memory or different? And the last question if we replace that SRAM Board instead of bubble memory board how to load software in it?
    Apr 2015
    45
    We had the CRP board problem before, when the machine was starting the machine gives us LIC C1 plane test NG addr error, and the machine didin't start up. So we bayed the CRP board but we are not sure that board might be a little bit different, so we are not sure that maybe this CRP board conflicts with bubble memory board and gives us now bubble memory error, or the CRP board is good, because we get an error after all test are made and the machine is booting forward
    Feb 2009
    6028
    Doesn't look like a bubble error there. That looks like a bus error for the fiber interface, like a dead operator panel or I/O...you unplug cables and put them in the wrong spot possibly?
    Aug 2011
    420
    I think faulty fiberoptic cable on operation panel
    "Imagination is more important than knowledge."
    Apr 2015
    45
    After we buyed the used cpr board from ebay it was not exactly the same but very similar because its hard to find exactly the same, and now when we replaced that board that error was solved, but then the machine loads and it gives "bubble memory error" i will post a photo when i will be in the job. So i think that we put the connections to to right place.
    Apr 2015
    45
    Maybe there is a way to show example of that cable? i will say to our service guy to check that cable.
    Apr 2015
    45
    The error with the new cpr board and old bubble memory board :
    The error with new CPR board and the new bubble memory board but as i found on internet on new bubble memory board swap need to reload software and that is not easy becouse need to have floopy drive reader and servar floppy disk we only have control disk i think paramters disk:
    Jun 2020
    64
    hi xal3r (or whoever reads) can you send me a picture of your 8 inch floppy disks? thanks, do you also have the 8 inch floppy drive? can you send me photos,
  1. Okuma LB15 OSP 5000L
    By CNCAndy in forum Mastercam
    Last Post: 01-23-2022, 08:09 PM
  2. Okuma LB-15 OSP 5000L (not the OSP 500L-G)
    By richardtheu in forum Okuma
    Last Post: 08-06-2016, 11:11 PM
  3. Okuma OSP 5000l-g software
    By partfinder2 in forum Okuma
    Last Post: 05-26-2015, 04:23 PM
  4. Okuma Osp 5000L
    By donbe in forum Okuma
    Last Post: 12-20-2013, 05:32 PM
  5. Okuma OSP 5000L M19 Code
    By devangrathod in forum G-Code Programing
    Last Post: 05-12-2012, 07:53 AM
