586,058 active members*
4,424 visitors online*
IndustryArena Forum > CAM Software > Vectric > I think something in my Gcode is resetting the surface Zero to -0.200"
Results 1 to 20 of 20
    Sep 2003
    1469
    Mach 3 V2, VcarvePro 8.5
    User since 2003, have went through my entire Z assembly and verified that i am not loosing steps, and everything is secure. Have never had this situation where the Z starts cutting deeper than it should.
    I think there is something in my gcode that is resetting my surface zero of the material from the initial of 0 to -0.200".
    I don't know much about gcode but at line "N74500G1Z-0.200OF5.0" this may be nothing but it looks fishy to me. that code is in other places of the file.
    I posted the too deep cut problem on this zone and after six pages of posts, mostly dealing with the hardware the suggestions was send it to a Mach, or Vectric specalist.
    Hope someone can help me, as i'm quickly approaching my Saturday deadline.
    I tried to post the code as another fellow asked for it but the file is too large, I really think someone needs to look at the code.
    HH
    Re: I think something in my Gcode is resetting the surface Zero to -0.200"
    That line just moves to Z -.2. It doesn't reset your Z zero.
    The chance that the code is wrong is incredibly small, as there are tens of thousands of V Carve users, and I haven't heard of any bad code.
    Sep 2003
    1469
    then what is resetting the Z?
    when i stop the program and use MDI and type "Z0" it goes 0.200" into the material ?
    how is the Zero point changing?
    15362
    Quote Originally Posted by Mr.Chips View Post
    The code you posted should send the cutter / tool down by -.200
    Do you have home switches are you homing the machine before you set your cutter offsets
    So when you set your cutter / tool offset G43 did you set the tool to the top of your part
    Mactec54
    Sep 2003
    1469
    In some instances the V bit will go dow 0.200" thats OK. But it should go down 0.200" from the surface of the material that I set to 0.000 before the program ran. and after the file run for a while if i stop the the file and use the MDI to move the Vbit doesnt to go to 000 it goes to 0.200".
    No home switches.
    if G43 means before the file runs, i set it to the top of the part yes to the surface of the part and hit the zero button on the Z axis, no offsets. i do set max depth to 0.300"
    hope this whart you are looking for
    thanks
    15362
    No home switches.
    thanks
    There is your problem Mach3 does not like stopping and being moved, if you have no Home, then it does not know where it is at, if you are not using offset then this will fail every time you stop and move it
    G54 is where your X0 and Y0 start point is stored
    G43 is where your Z axes 0.0 position is stored if you don't have this in your program then when you stop the control does not know where to start
    N1G17G40G80
    G0Z2.
    T1M6
    G54
    S12000M3
    G90G0X0.Y0.
    G43Z.2H1
    Program
    Mactec54
    Sep 2003
    1469
    In response to your “that’s your problem”
    If by HOME do you mean a master HOME position goes to day in and day out. In that case I do not have a HOME
    To my knowledge I have never used OFFSETS
    sorry I’m not very savvy to the “calls” you are referring to. I have used this Homemade CNC for ten years and have ran files like I am having problem dozens and dozens of times and never had this problem.
    I realize you are trying to help, however I don’t find you statement to be true in at least my case, I apologize if I am not understanding you, please continue to help me solve my problem
    I have a short file created in VCP it says “can you hear me now” using the VCP text editor, and V but cutting.
    i Move to a point above the material, zero x And y, then using the paper method zero Z to the surface.
    start running the file and I moused the STOP button on the screen
    Using the arrow buttons on keyboard I raise the Z approximately 1/2” above the surface
    Using the arrow button on keyboard I move the X axis to a random location off the cut area, but above the material.
    Click the on screen MDI and type “Z0. And it lowers perfectly to the surface of the material.
    i repeated the above three times at different random points of the running program and it always returned to the surface of the material using the MDI command.
    am I missing something. Please don’t give up something is amiss just don’t know what.
    thanks
    HH
    15362
    thanks
    HH
    Post the whole program Just copy past it
    The way you have been doing it for 10 years you got lucky it can work like this but will never be reliable
    Mactec54
    Sep 2003
    1469
    It’s too big to upload
    Aug 2009
    1573
    make into 2 or 3 files..with a Text Editor.
    Sep 2003
    1469
    The Vectric forum ran it without any problems, so that means it’s either Mach or my machine, there going to give me a testing routine, which I’ll run and see how it goes.
    Aug 2009
    1573
    Looks like you designed and build a nice machine from looking at your Photo's in the other Thread. Adding a Counter Weight to Z Axis might be needed, but if it has run for ten years without one maybe not.
    Next is Tuning the Z Drive is my guess to fix your problem. The Make, Model, and SN's of both the Z Axis Motor and Drive will be needed for anyone with knowledge to walk you thru the tuning would help I'm sure. Maybe a pdf file or link...what ever is possible.
    DJ
    15362
    I looked in your other thread on this same problem
    Here is something for you to try, I have 2 things that may be causing you problem
    Can you run through the program without the router running you could easily have a noise problem for that router that is causing a problem with the Z axes stepper motor
    The other problem is you should not be programing using a G91.1 as if there is any error this will make it worse
    Mactec54
    Sep 2003
    1469
    Thanks but in in the process of reinstalling MACH3. If the new copy of Mach doesn’t fix it I’ll be back searching for solutions.
    The G91.1 is fine.
    Mactec doesn't know what he's talking about.
    15362
    The G91.1 is fine.
    Really I said it was something to try, G91.1 this is not normally use for any type of programing and was only developed for users that could not understand how to setup there machines, it is totally not needed if the control is setup correctly
    If you can prove other wise we are all listening
    G90.1 & G91.1 Set IJK Arc Mode
    Interpretation of the IJK values in G02 and G03 codes can be in one of two distance modes: absolute or incremental.
    To go into absolute IJ mode, program G90.1. In absolute distance mode, IJK numbers represent absolute positions in terms of the currently active coordinate system.
    To go into incremental IJ mode, program G91.1. In incremental distance mode, IJK numbers usually represent increments from the current controlled point.
    Incorrect settings of this mode will generally result in large incorrectly oriented arcs in the toolpath display.
    Mactec54
    15362
    Your Mach3 was running ok you proved that by using other programs
    Like I said run the program with the Router turned off
    Mactec54
    On the contrary, this makes sure there won't be any issues.
    You've been trying to tell people for years not to use G91.1, when in reality, it prevents users from having errors.
    15362
    It does not prevent anything if the control is setup correct
    It's only a simple I &J setting in Mach3 that takes care of any problems anyone may ever have
    If this is set correct in General Config. there is no need for it to be in the program it serves no purpose
    Mactec54
    Aug 2009
    1573
    Z axis drive is stalling is the most likely the problem when using an Open Loop feedback system.
  1. Is there any "dxf to gcode" open source code implemented by c++?
    By yfyfly in forum Uncategorised CAM Discussion
    Last Post: 11-14-2016, 05:08 AM
  2. K2 with kmotionCNC "G Code Error GCode Aborted"
    By Dimebag_cnc in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-28-2015, 08:59 PM
  3. Replies: 7
    Last Post: 06-12-2015, 03:31 PM
  4. Program for "Figure primitives" gcode
    By Thor_ in forum Uncategorised CAM Discussion
    Last Post: 05-16-2015, 01:24 AM
  5. Lost ability to "post gcode"
    By John Tribe in forum Uncategorised CAM Discussion
    Last Post: 07-07-2008, 07:56 PM
