586,100 active members*
3,125 visitors online*
    Apr 2019
    Error code 272
    I have a mazak multiplex 430, I keep getting an error code 272 turret index exceeded time and then it will not read even numbers for the tool positions on head #2. Can anyone help me fix this issue please?
    Apr 2019
    Re: Error code 272
    Your machine's HDD may have bad sector or some damages. Check HDD 1st. I used to recovery data from bad HDD for my friend and the problem was resold.
    Sep 2017
    139
    Re: Error code 272
    Kindly share the complete alarm description to identify the exact cause. Or you may check the alarm code appearing on the turret drive unit and share it, so that proper guidance can be given
