Hi guys, i'm ordering parts for my first cnc build and the thing that confuses me the most by now is the proximity switches. I want to know what kind of sensors should i order first and than what is the best way to connect them. I want to order 6 pcs connect them in series NC type, 3 wires, inductive proximity switches and they say they work on 6-36v.
q1- what is the difference between supplying them with 6-12-24-36v will the sensors behave different on different voltage or it doesn't matter? (i plan to run them on 12v)
q2- i have seen many different ways to connect them, what is the most reliable way? (i plan to do it in series with 12to5v relay on the signal)
correct me if i'm wrong
extra question what do you think about the idea of using step down on the signal instead of using resistors or relay ?
i will use DB25 bob like that in the attachment, if that is even the name for the bob :/
