586,113 active members*
3,154 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > pass depth and feed speed for a profile cut
Results 1 to 1 of 1
    Nov 2018
    6
    Hello.
    I am milling this sculpture which is about 120 mm x 1900mm x 800mm. I need to mill it on both sides. For the profile cut, i have a 100mm long bit with a diameter of 8mm that needs to cut 60mm deep to the half of the material thickness, and then i need to turn the material over and cut the other 60mm.
    In order to make these cuts, how much can my pass depth be and what maximum feed rate can i have? I did a test and with a 1mm pass depth and 2000mm/min feed speed, i get an estimated time of around 11 hours.
    I am trying to make this cut time shorter and i wonder if i can speed up the feed rate, or make the pass depth higher? Or any other suggestion to shorten the cut time?
    Thanks!
