586,103 active members*
3,684 visitors online*
IndustryArena Forum > CAM Software > CamBam > 3D Profile problem
    Nov 2008
    11
    3D Profile problem
    Hi I'm trying to generate G code for my 3040 to make a "bit fan".
    I have G-code for a 1/16" bit, but I want to use a better 2mm cutter I already have.
    The place that supplied the 1/16 bit code also supplied an STL.
    Having loaded that into CamBam, I can't figure out how to get it to generate the right tool paths make the 3D shape.
    All I've been able to get it do do is get it to clean out the spaces between the blades, but not shape the blades themselves.
    The page with the files is here:
    https://blog.bantamtools.com/introdu...y-you-can-make
    I'm trying to make a 1/4 inch thick version.
    While the STL model is double sided, I can get away with using a one-sided version.
    Feb 2012
    Re: 3D Profile problem
    FAN G-code: Mach3 (mm) Start left front top corner. Ø2 mm end mill. Change extension .txt to .nc
    Attachment 417660
    Attachment 417664
    Attachment 417666
    Nov 2008
    11
    Thanks. I'll give that a go in the morning.
    Feb 2012
    Hey!
    Tried to manufacture the fan in the 3D printer, and the outer wall was too thin to print. Changed the fan so that it has 2 - 3 times as much material. See picture.
    .nc and .stl files cannot be uploaded! Change .txt to .nc and .stl respectively. If the file cannot be opened with Mach3, open it first in eg TextWrangler.
    .stl file was too big to upload!
    MVH Anders
    Attachment 417846
    Attachment 417848
    Attachment 417850
    Attachment 417852
    Nov 2008
    11
    Thanks for the help.
    I've actually managed to sort it out in Fusion360.
    It's a bit rough, but it works.
    Thanks again.
  1. 3D Profile problem - too many passes
    By Busch_dk in forum CamBam
    Last Post: 02-24-2014, 08:29 PM
  2. Help with profile cut and tab problem
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 05-05-2013, 07:36 PM
  3. 2 1/2 Profile Bridges problem
    By chris123 in forum Visual Mill
    Last Post: 10-14-2010, 01:21 PM
  4. 2.5d profile problem
    By MadeInTheShed in forum CamBam
    Last Post: 11-19-2009, 06:32 AM
