586,116 active members*
3,469 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Anilam crusader m control problem.
Page 4 of 4 234
Results 61 to 79 of 79
  1. #61
    Mar 2005
    271
    Quote Originally Posted by PCW_MESA View Post
    This is dependent on how the drives enable signal works, have you found any documentation on the drive or original mill wiring diagrams?
    Do you have the drive part number and manufacturer?
    Anilam Crusader M control.
    Servo Drives
    EG&G Torque Systems servo drive
    Model number ACU3015-100D
    Can't find any documentation for these but I do have original wiring diagram.
  2. #62
    Feb 2008
    644
    Re: Anilam crusader m control problem.
    Quote Originally Posted by CATCH22 View Post
    Servo Drives
    Can you post the wiring diagram section that shows the connections to the servo drives J1 connector?
  3. #63
    Mar 2005
    271
    I can't find a J1 anywhere, but here is what I think you are looking for.
    Thanks Mike
  4. #64
    Feb 2008
    644
    Thanks Mike
    Not sure I can really interpret that drawing very well
    Basically you need to know these things about the drives:
    The location of the analog input pins on the drives
    The location of the drive enable pin(s)
    How the drive enables work
    (are they enables, disables, do you pull them high, low etc)
    Without this information its going to be hard to proceed
    If you have a friend that is knowledgable about electronics that would help
    as would a drive manual or a drawing that labels the pins, or even a close picture of the
    drive including the interface connector (J1) and existing Anilam wiring
  5. #65
    Mar 2005
    271
    Would I be better off going with the AMC 25A20 drives I have, I just thought it would be easier to just use the original drives for now because I don't have a clue what I'm doing. Lol
  6. #66
    Dec 2013
    5717
    I've been following along here and have to say the the AMC 25A20 drives might be the best idea if you have documentation for them. Any device with more than two connections on it and without documentation is pretty much a paperweight.
    Jim Dawson
    Sandy, Oregon, USA
  7. #67
    Mar 2005
    271
    OK before I go switching to the other drives I found this servo circuit board drawing, if this does not have the information I need then I will switch drives.
    Thanks Mike
  8. #68
    Dec 2013
    5717
    Thanks Mike
    I'm afraid that is the drawing for the relay (801) board, not the servo board.
    Jim Dawson
    Sandy, Oregon, USA
  9. #69
    Mar 2005
    271
    OK thanks Jim, I guess I will start installing new drives this weekend.
  10. #70
    Mar 2005
    271
    OK so I pulled the original drives and I'm going to start wiring the new AMC BE25A20 drives, they are brushless drives but I setup the switches on the drive to run brushed servo motors. Now I need to know where to hook up the existing wires on the servo drives. Now there are 2 orange and 2 grey wires for the power do I just use 1 of each of these or do I tie the 2 together and hook them to the drive. There is also 2 light blue wires and 2 purple wires that went to the old servo drives. OK and on the other small connector there is a brown, green and yellow wire that are coming off of the 15v power supply, obviously 2 wires are for power but what is the 3rd wire for. Sorry this is so long just do not want to screw this up. Thanks in advance for your help.
    I also have 3 brushed drives also if they would be easier to setup.
    Thanks Mike
  11. #71
    Mar 2005
    271
    Here are 2 pics of the drives.
  12. #72
    Dec 2013
    5717
    The AMC BE25A20 drives seem to be the most compatible with the Mesa hardware that you have in that they accept a +/- 10VDC analog control signal, so I would use them. The brushed drives look like they want a PWM and Direction control signal, and I don't know if your Mesa hardware has that control output available.
    The orange and gray wires are pretty small so I would use them doubled just to carry the current.
    As far as the other wiring, remove all of it. You need to start from scratch since you are replacing both the drives and the controller. The +/- 15V power supply won't be needed either, the AMC drives have that built in. Sit down and draw a diagram of how you are going to wire things up, much easier to fix the mistakes on paper.
    The only wiring that needs to be left intact is the power wiring, fans, and other stuff, no need to change that. If you have a 24VDC power supply in the cabinet, then leave that also. Will be useful for powering limit switches and other devices as needed.
    Jim Dawson
    Sandy, Oregon, USA
  13. #73
    Mar 2005
    271
    OK thanks a lot Jim, I really appreciate it.
  14. #74
    Mar 2005
    271
    Hey Jim, do I keep using the inductors for each axis.
    The purple and blue wires are the power wires to the inductors. Then to the servo motors.
  15. #75
    Dec 2013
    5717
    Sure, keep the inductors in place. Can't hurt anything.
    Jim Dawson
    Sandy, Oregon, USA
  16. #76
    Mar 2005
    271
    Should I setup the servos in torque mode or velocity mode, from what I have been reading torque mode is easiest and is a bit tighter. And I also uploaded a drawing if you could have a quick look at it and let me know what you think.
    Thanks Mike
  17. #77
    Dec 2013
    5717
    I normally use torque mode, seems to work better
    The only thing I see in the diagram that I question is the enable relay, normally you would use the ENA pins rather than an output on the MESA board.
    Jim Dawson
    Sandy, Oregon, USA
  18. #78
    Mar 2005
    271
    So from what I have been reading I don't use the tach at all, it just uses the glass scales for positioning.
  19. #79
    Dec 2013
    5717
    If the AMC drive does not require tach feedback for a brushed DC motor then no need to use it. The MESA board only requires encoder (glass scales in this case) feedback.
    Jim Dawson
    Sandy, Oregon, USA
Page 4 of 4 234
  1. Programming Anilam Crusader II L Lathe Control
    By 57chevy in forum Controller & Computer Solutions
    Last Post: 06-03-2014, 06:30 PM
  2. help repairing Anilam Crusader II control?
    By wddanie in forum Bridgeport / Hardinge Mills
    Last Post: 02-15-2013, 06:03 PM
  3. My New/Old Anilam Crusader M has a problem
    By L98FIERO in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2008, 01:10 PM
  4. ANILAM CRUSADER II Problem
    By ataylor_316 in forum Bridgeport / Hardinge Mills
    Last Post: 09-21-2007, 12:04 PM
  5. Anilam Crusader M problem
    By Rot Iron Racer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-18-2007, 08:15 PM
