586,071 active members*
4,360 visitors online*
Page 2 of 3 123
Results 21 to 40 of 53
  1. #21
    Aug 2010
    686
    Re: CNC Construction Set Build 3 Blog
    Volume 2 - Chapter 11 - Z Axis ACME Screw
    Installed the Z axis ACME screw.
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
  2. #22
    Aug 2010
    686
    Volume 2 - Chapter 12 - X ACME Screw
    I cut and installed the X axis ACME screw.
    Attachment 417036
    Note that I am using the helical shaft couplers. I have found that these work the best for this build.
    Attachment 417038
  3. #23
    Aug 2010
    686
    Volume 2 - Chapter 13 - Z Carriage Install
    Z carriage installed.
  4. #24
    Aug 2010
    686
    Volume 2 - Chapter 14 - Y Axis ACME Screws
    The Y axis ACME screws have been installed.
    Attachment 417044
    The End of the shaft coupler should be about 1/4" from the rear edged of the mount as shown here.
  5. #25
    Aug 2010
    686
    Volume 2 - Chapter 15 - Conclusion
    It's just about time to get this baby going.
    Volume 2 is now complete.
  6. #26
    Aug 2010
    686
    Volume 3 - Chapter 1 - Getting Started
    Started getting parts together for the electronics.
    Volume 3 - Chapter 2 - Layout Board
    Board completed.
    Volume 3 - Chapter 3 - Mounting the Power Supply
    Power Supply Mounted.
  7. #27
    Aug 2010
    686
    Volume 3 - Chapter 4 - Mounting the G540
    G540 Mounted
    Volume 3 - Chapter 5 - Terminal Blocks
    Terminal blocks installed.
    Attachment 417060
    Volume 3 - Chapter 6 - Wiring
    Wired up.
  8. #28
    Aug 2010
    686
    Volume 3 - Chapter 7 - Mach3 Install
    Mach 3 Installed. Note that I am using an old Windows 7 PC for this. In time it will move to a small form factor Windows 10 PC.
    Attachment 417064
    Volume 3 - Chapter 8 - Mach 3 Config
    Mach 3 Configured.
  9. #29
    Aug 2010
    686
    Volume 3 - Chapter 9 - UC100 Install
    UC100 Installed and working.
    Attachment 417068
    I plan on installing the UC300ETH and configuring it. I will do that after I go through Volume 3 completely so I can iron out any issues in the book.
    A tornado hit our local Amazon distribution center so any thing I order is taking weeks, Once some of the parts needed for the advanced electronics volume finally get here, I will start as I suspect I will have volume 3 testing complete.
  10. #30
    Aug 2010
    686
    Volume 3 - Chapter 10 - Motor Cables
    Motor Cables Built.
    On this build I added rear covers and connectors to the Motors.
    While you don't have to add connectors to your motors, I do it because I change things around all the time.
  11. #31
    Aug 2010
    686
    Volume 3 - Chapter 11 - Motor Setup
    Motors setup in Mach 3.
    Attachment 417074
    My layout board is placed on the lower shelf I added earlyer. As this is only an option, you will need to come up with some sort of table to hold the layout board if you did not add this lower shelf.
    Attachment 417076
  12. #32
    Aug 2010
    686
    Volume 3 - Chapter 12 - Installing the Motors
    Volume 3 - Chapter 13 - Motor Tuning
    Motors installed and tuned.
  13. #33
    Aug 2010
    686
    Volume 3 - Chapter 14 - Conclusion
    I did some temporary cable management.
    Attachment 417090
    Attachment 417092
    Volume 3 is now Complete
    This wraps up the third volume. I have added some content to the CNC Construction Set area on the Kronos Robotics website. I will post links in this blog as I complete them.
  14. #34
    Aug 2010
    686
    Volume 3B
    I upgraded the machine to advanced Electronics as per the Volume 3B book.
    Advanced electronics, while a little more expensive lets you move into some more advanced operations, such as plasma cutting or adding a rotary axis.
    I have added a drag chain upgrade and mounted the layout board to the machine.
    You can find the upgrades here:
    CNC Construction Set Upgrades
    Accessory Brackets
    Attachment 417132
    Writeup here:
    https://www.kronosrobotics.com/cnccsaccessorybrackets
    Mounting the Layout Board
    Attachment 417134
    Writeup here:
    https://www.kronosrobotics.com/cnccslayoutboard
    Cable Management
    Attachment 417130
    Write up here:
    https://www.kronosrobotics.com/cnccscablemanagement/
  15. #35
    Aug 2010
    686
    Machine Break-in
    It't time to do some break-in on the new machine.
    https://youtu.be/n09wbFiarMs
    I did a writeup on my break-in procedure here:
    CNCCS Breakin
  16. #36
    Aug 2010
    686
    Basic CNC Tables
    I did a writeup on adding various table types to the CNCCS.
    You can find it here:
    https://www.kronosrobotics.com/cnccstables1
    Here I am using one of the tables to do a drawing test.
    https://youtu.be/3d8rdRvC6-o
  17. #37
    Aug 2010
    686
    Router Mount
    I added a CNCRouterParts router mount to the build.
    Attachment 417138
    This means you can use any of several spindles or routers with the CNCCS (CNC Construction Set)
    See my writeup here:
    https://www.kronosrobotics.com/cnccsroutermount
  18. #38
    Aug 2010
    686
    Z axis bearing mount brace
    A small brace to keep the Z bearing mount.
    Attachment 417140
    Writeup here:
    https://www.kronosrobotics.com/cnccszbrace
  19. #39
    Aug 2010
    686
    At this point this point, I will start the plasma table upgrades for the CNCCS (CNC Construction Set) build. This upgrade will allow me to perform CNC plasma cutting operations. I can still add clamp tables and spindle/router carriages to perform milling operations.
    Attachment 417154
  20. #40
    Aug 2010
    686
    Volume 5 - Chapter 2 - Side Table Supports
    Side supports installed.
    Attachment 417160
    Volume 5 - Chapter 3 - Leveling Table Supports
    Supports leveled.
    Attachment 417162
    Volume 5 - Chapter 4 - Center Support
    Center support installed and leveled.
    Attachment 417164
Page 2 of 3 123
  1. Replies: 35
    Last Post: 03-13-2018, 03:41 AM
  2. New Design/Build: CNC router (steel plate construction) + Raspberry Pi
    By cmadki4 in forum DIY CNC Router Table Machines
    Last Post: 09-24-2017, 03:11 PM
  3. Replies: 4
    Last Post: 07-24-2013, 11:48 AM
  4. DIYLILCNC PVC Build - Bed Construction
    By jimmycakes in forum DIY CNC Router Table Machines
    Last Post: 12-10-2010, 05:58 PM
  5. 9'X5.5' Router table - Build Blog...
    By turbotoys in forum DIY CNC Router Table Machines
    Last Post: 09-13-2007, 04:20 PM
