586,318 active members*
3,517 visitors online*
Page 1 of 3 123
Results 1 to 20 of 53
    Aug 2010
    686
    CNC Construction Set Build 3 Blog
    First a little history.
    CNC Construction Set Build 1
    Build 1 consisted of several iterations of the early prototype. The plate material used was Corian. The Corian was very easy to cut and drill with standard woodworking tools. Corian can be a little pricey if you cant locate any locally. While I did develop some interchangeable Z carriages, this machine is primarily set up as a plasma CNC.
    Shown here it has a floating head IHS and a steel angle cutting fixture.
    Attachment 417100
    CNC Construction Set Build 2
    Build 2 used PVC as the plate material. While this was very easy to cut and drill, it is not as rigid as the build using the Corian plates. This machine I am currently using for milling and to test my rotary axis.
    Shown here, build 2 has many upgrades added that I will eventually be documenting.
    Attachment 416896
    In this blog, I will be covering build 3.
    Very happy with the build so far, I decided to start a third build, using MDF. Since this plate material is listed in the book I needed to try it out. I will also be doing the advanced electronics option on this build since it will also support CNC operations.
    If you would like some more information covering the CNC Construction Set builds, you can get it here:
    https://www.kronosrobotics.com/cnccsintro
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
    Aug 2010
    686
    Re: CNC Construction Set Build 3 Blog
    Volume 1 - Chapter 1 - Getting Started
    The Stand
    The stand I am using for the CNC Construction Set is a readily available steel stand.
    Shown here are the parts as they arrive from Rockler.
    Attachment 416898
    It took me about an hour to assemble the stand.
    Attachment 416900
    I did add some white peg board as a lower shelf so I would have a place to put my PC and electronics.
    Attachment 416902
    Attachment 416904
    One thing I added as an option were these heavy duty leveling castors.
    Attachment 416906
    Attachment 416908
    Aug 2010
    686
    Volume 1 - Chapter 2 - The Frame
    I gathered all my components and assembled the angle brackets.
    Attachment 416912
    Attachment 416910
    Brackets were installed on the lower three slots of the short frame components.
    Attachment 416914
    I then finished the frame assembly.
    Attachment 416916
    I marked the location for the frame mounting hardware using a light blue pencil.
    Attachment 416918
    Finished Frame/Stand Assembly.
    Aug 2010
    686
    Volume 1 - Chapter 3 - Y Rails
    I received the replacement Y-rails today. So I was able to finish the Y-rails chapter. It went smoothly. I did make a few small changes to the book but nothing significant.
    Attachment 416922
    Attachment 416924
    Be sure to give the shafts a good soaking in oil, then wipe them with a paper towel.
    Aug 2010
    686
    Volume 1 - Chapter 4 - Y Carriages
    I finished the Y-carriages.
    Attachment 416928
    Attachment 416930
    The only glitch I had was one of the holes used to mount the plate to the truck was off. To fix, I just enlarged the hole a little. This just shows you that even if you are using a template, if you don't place you punch correctly, your hole will be off. I was moving a little too fast and needed to slow down a little.
    Aug 2010
    686
    Volume 1 - Chapter 5 - X Rails
    Finished the X-rails.
    Aug 2010
    686
    Volume 1 - Chapter 6 - Gantry
    I attached the templates to my riser plates and marked the holes and cutout.
    Attachment 416936
    The gantry attached to the risers.
    Attachment 416938
    The left risers look a little skewed. This can be caused by the plates not square with the gantry beam or the frame is not exactly square. Not an issue as it will be corrected in the tuning phase. However it is important that the riser blocks are not sticking past the extrusion or it may cause some issues later.
    Attachment 416940
    Here is some cleanup I had to do later because they were sticking out. It would have been easier to fix the mount now the wait till later and have to use a hand plane like I did.
    Aug 2010
    686
    Volume 1 - Chapter 7 - Gantry Brace
    I attached the templates to the gantry 1" angle. In my case using MDF the gantry braces were exactly 10".
    Attachment 416946
    Aug 2010
    686
    Volume 1 - Chapter 8 - X Carriage
    I attached the template to the plate stock
    Attachment 416958
    The mounted carriage
    Attachment 416960
    Aug 2010
    686
    Volume 1 - Chapter 9 - Z Rails
    I cut my Z rails
    Attachment 416962
    And mounted them on the X carriage.
    Attachment 416964
    Aug 2010
    686
    Volume 1 - Chapter 10 - Z Carriage
    I marked my Z carriages and risers using the templates.
    Attachment 416966
    Starting to come together.
    Attachment 416968
    This concludes Volume 1.
    Aug 2010
    686
    Volume 2 - Chapter 2 - Tuning the Gantry
    I built the gauge block. (covered in the book)
    Attachment 416970
    I did have to make a little adjustment to the lower rail. But it only took a couple minutes and it turned out perfect.
    Attachment 416972
    Aug 2010
    686
    Volume 2 - Chapter 3 - Work Table
    Nuf Said ...
    Attachment 416976
    Aug 2010
    686
    Volume 2 - Chapter 4 - Tuning the Z-carriage
    The X and Z carriage are now square and tuned.
    Attachment 416978
    I did notice a few things. The trucks I used on the Z carriage had preloaded grub screws on the sides as well as the top. This may vary even from the same manufacture, but the procedure is the same. Tighten the grub screws until there is no play in the truck on the rail. If it does not slide smoothly, back it off a little.
    Aug 2010
    686
    Volume 2 - Chapter 5 - Pen Holder
    I used the optional templates to mark my holes and cutouts.
    Attachment 416980
    Attachment 416982
    I drilled the tool holder holes.
    Attachment 416984
    This is the optional pen holder. I drilled all the holes before I made the two corner cutouts.
    Attachment 416986
    Simple pen holder installed.
    Attachment 416988
    Aug 2010
    686
    Volume 2 - Chapter 6 - Squaring the Gantry
    Got the gantry all squared up. It took me a couple extra attempts as I was moving a little too fast for my own good. Take your time with this one.
    Attachment 416990
    I did finish the more advanced pen holder. This one can also hold other tools such as a drag knife.
    Aug 2010
    686
    Volume 2 - Chapter 7 - Y Drive Plates
    The templates attached to the plate stock.
    Attachment 416994
    With hardware installed.
    Attachment 416996
    Attached to the machine.
    Attachment 416998
    I have included a little fancier design.
    Aug 2010
    686
    Volume 2 - Chapter 8 - X Drive Mounts
    I used the templates to lay out the bearing and motor mount holes.
    Attachment 417002
    I calculated my reference line and attached the two extrusion mounting templates.
    Attachment 417004
    As an option you can use the corner cutout template to shape the X drive mounts. This cut is optional and is for aesthetic purposes only. Once I cutout the corners, the mounts are ready for the final paint.
    Attachment 417006
    Mounted
    Attachment 417008
    Aug 2010
    686
    Volume 2 - Chapter 9 - Y Drive Mounts
    I attached the templates:
    Attachment 417012
    Ready for the final finish:
    Attachment 417014
    Mounted:
    Attachment 417016
    Don't forget to remove the work table and T-nuts before installing the front mounts. I did and had to go back and remove them to get the table off.
    Make sure you add the 6 T-nuts to each side of the frame as shown here:
    Aug 2010
    686
    Volume 2 - Chapter 10 - Z Drive Mounts
    I attached the templates as usual and marked my holes.
    Attachment 417024
    I used a small vise to hold the plate while I drilled the edge holes.
    Attachment 417026
    All the hardware installed. Remember to remove the Z-carriage before installing the Z drive mounts.
    Attachment 417028
    The drive plates installed.
    Attachment 417030
Page 1 of 3 123
  1. Replies: 35
    Last Post: 03-13-2018, 03:41 AM
  2. New Design/Build: CNC router (steel plate construction) + Raspberry Pi
    By cmadki4 in forum DIY CNC Router Table Machines
    Last Post: 09-24-2017, 03:11 PM
  3. Replies: 4
    Last Post: 07-24-2013, 11:48 AM
  4. DIYLILCNC PVC Build - Bed Construction
    By jimmycakes in forum DIY CNC Router Table Machines
    Last Post: 12-10-2010, 05:58 PM
  5. 9'X5.5' Router table - Build Blog...
    By turbotoys in forum DIY CNC Router Table Machines
    Last Post: 09-13-2007, 04:20 PM
