586,332 active members*
4,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Colchester Triumph 7.5" (Round Head) Lathe
    I have a Colchester Triumph 7.5" Mk1 (Round Head) which is used every day in our machine shop. It's an old girl, but it is priceless to our business and is still used just as much as the other lathes.
    Today however it's given up. We can still select all gears on top (two levers) but the main high / low gear lever on the front is the issue. In low box all is fine. In high box when running the spindle slowly moves in its correct direction. But it doesn't pick speed up and I can stop it by hand.
    I've removed the head off the gearbox and noticed that the high speed driving gear (drives spindle tube through selector) is spinning freely on the shaft. See attached pictures and video.
    http://81.138.85.180/~jim_cliff11/Triumph.mp4
    I can’t find any tech drawings for this lathe. There is no grub screw, roll pin or bolt to hold the gear onto the shaft so I can only assume its fixed to the shaft through splines. And subsequently the splines have worn off? However, it went from working fine to not in the space of 5 minutes with no grinding or typical gearbox failure sounds.
    Does anyone have any experience with these lathes, and would be kind enough to advise?
    15362
    Re: Colchester Triumph 7.5" (Round Head) Lathe
    Quote Originally Posted by jim_cliff11 View Post
    I think if it had worn the splines off there would be a lot of metal shaving that you would be able to see, you are lucky that you are in the UK there are still plenty of parts available for these old machines and a great machine as well, I have 2 but have not had that model I have a latter model 2000 and a ChipMaster I only have the manual for the ChipMaster which does have the back Gear similar to this as well
    The 600 Group will have parts for you, this guy will also be able to help you with what is wrong, [email protected] I think you can remove that shaft there are some cover plates on the front and back and you can remove that shaft from there, make sure everything is cleaned before you take any parts off I have only done the ChipMaster Gear Box so not sure with yours
    Mactec54
  1. Colchester Triumph Electronic Lathe
    By bitson555 in forum Colchester Tornado lathes
    Last Post: 03-18-2017, 08:59 AM
  2. Colchester triumph 2000
    By stang073 in forum Uncategorised MetalWorking Machines
    Last Post: 07-17-2012, 08:26 AM
  3. Colchester triumph 2000
    By stang073 in forum Australia, New Zealand Club House
    Last Post: 07-11-2012, 11:04 AM
  4. COLCHESTER TRIUMPH 2000 LATHE
    By DB23 in forum Uncategorised MetalWorking Machines
    Last Post: 02-15-2011, 12:40 PM
  5. Colchester Triumph lathe
    By bigpete_h in forum Vertical Mill, Lathe Project Log
    Last Post: 07-05-2010, 02:04 AM
