Originally Posted by
Erik F
To test out if the extrusions under the rails will help me get things right, I am going to design some parts I can 3d print out of polycarbonate blend I have on hand. If they work well enough I may just leave them in place, also if they work well I will post up a link to the file for others to print or have printed. I'm trying to decide how extensive I want to make them...for example making them so you can adjust "toe in / toe out" as far as flatness goes. On my last and final attempt to parallel the rails, I had one rail tightened down and it rolled very smoothly with the other rail loose...when I tried the same test with the rails reversed (swapped tight and loose rails) the action was back to being with much more drag...seemed odd to me.
