Hi all,
I've just had a CNC6040 delivered (well, it appears to be a 6040) and it claims to have a TX14175 inside (based on the silkscreen on the board inside it).
I'm using LinuxCNC - and despite my best google-fu I'm not getting very far. It doesn't even sound like it's trying to move (let alone actually moving).
I've tried a couple of configs I've found on here for TX14175 boards, but I cannot get it working. The one I thought most likely to work is the following:
1 PWM
2 X step
3 X dir
4 Y step
5 Y dir
6 Z step
7 Z dir
8 A step
9 A dir
14 Enable
16 B step
17 B dir / Relay
It didn't work for any axis. Is there a definitive TX14175 pinout (appreciate that axes might be swapped between models)? Am I likely to have a dead/half-wired parallel port? A dead TX14175?
I've since been through trying the enable pin on every pin apart from 4-7 - and there is no noise from the steppers. They do, however, engage at startup as I hear that.
The actual box itself looks like the attached image.
Does anyone have any suggestions for what to try next?
Thanks in advance.
Chris
