586,626 active members*
2,440 visitors online*
    Chinese Tailstock FAIL
    Is this not the most sh**ty thing you have seen on a cheap chinese mini lathe tailstock, or is this all too common?
    Left side quarter inch gap between bed and base?
    Ironically the height is about center, so making the triangle bigger to make it flush will lower the center height by a quarter inch.
    I believe the best bet here would be to mount a steel or brass 1/8in or so plate under everything but the triangle area to make it level.
    That is of course just a short term solution instead of making a new bottom plate correctly to begin with.
    Let me know your thoughts, thanks.
    Re: Chinese Tailstock FAIL
    Image link error upload.
    https://i.ibb.co/xjZSCky/1Copy.jpg
    Nov 2005
    222
    I would bet that is the wrong tailstock. It looks like it is for a smaller lathe.
    Consider case closed, found another user who just replaced the whole bottom plate.
    It turns out to be less work to just use steel instead of cast iron and hope the vibration plays well with titanium.
    https://www.youtube.com/watch?v=Il4EuovJ3c8
  1. Fail to Load #971
    By GR3G_CNC in forum Haas Mills
    Last Post: 11-04-2021, 03:43 PM
  2. 4th axis rotary and tailstock...chinese parts? opinions?
    By airbrush in forum DIY CNC Router Table Machines
    Last Post: 06-14-2016, 03:21 PM
  3. HSM Miserable fail.
    By Jon.N.CNC in forum Autodesk CAM
    Last Post: 09-30-2015, 07:14 PM
  4. Chinese motors crap or do i fail?
    By S30z in forum Stepper Motors / Drives
    Last Post: 08-25-2013, 02:48 PM
  5. 325 PROC WDT FAIL
    By ramsey321 in forum Tree
    Last Post: 09-14-2010, 04:47 PM
