586,061 active members*
4,308 visitors online*
    Mar 2011
    357
    placement of VFD
    I am building a 4 ft x 8 ft router and am contemplating installing the VFD on the gantry to save some money on the expensive double shielded cable.
    My gantry is all steel but my table is wood.
    So, I have several questions.
    Is it ok to mount the VFD on the gantry?
    If not, why?
    If yes, how do I properly ground the shield back to the control box?
    Sep 2005
    1740
    Re: placement of VFD
    I would not mount on gantry, needs to be in a metal box grounded and mounted on the frame. It cost me less than $60 USD for my shielded power cable.
    Nov 2012
    1267
    A month ago I ran into a serious problem when I mounted a VFD on a moving carriage of a LARGE woodworking machine (takes a whole tree log and makes it perfectly round). The VFD failed in just a couple weeks. The reason? The vibration was strong enough to break the pins off the large capacitors inside the VFD.
    I had to make some "prosthetic legs" for the capacitors and glue them to the circuit board. It works so far, but next time I will mount a VFD elsewhere.
    Mar 2011
    357
    Quote Originally Posted by CitizenOfDreams View Post
    Dang that is a good reason not to for sure
  1. Stock placement?
    By Fastest1 in forum BobCad-Cam
    Last Post: 08-01-2010, 11:40 PM
  2. placement of controlers
    By letmefixit in forum CNC Machine Related Electronics
    Last Post: 05-02-2010, 09:38 PM
  3. IGF M08 placement
    By flick in forum Okuma
    Last Post: 08-12-2009, 05:02 AM
  4. Machinest placement
    By logos in forum Employment Opportunity
    Last Post: 12-12-2006, 09:32 AM
