586,106 active members*
2,987 visitors online*
    K40 laser problems when turning on
    I recently bought a SH K40 Chinesse laser engraver and I tested by pressing the "Laser switch", adjusting the current regulation, adjusting the mirrors and stuffs like that. By doing that I think I break something, or something happened with the rail because when I try to move the laser head from the K40 Whisperer, it does initiaze, I can move the Y axis by pressing the arrow down, but when I try to move the head to the right, nothing happened. Try this several times, no result.
    The last thing that I saw is that every time I hit the Initialize Laser it will go down a little bit until it will hit the limit.
    Video to see that the X axis is not responding : https://streamable.com/yetr2
    Found out this large white wire was being pulled out from the stepper...
    Ok so I plugged in the white wire back into the stepper... and the laser went crazy. I also tried to flip the wire in the plug but it behaves like it was in the beginning with no response from the X axis. Somehow now the axis are moving but terrible wrong...
    Video here : https://streamable.com/vrifo
    I don't have a clue what could possibly went wrong with this laser machine.
    Any advice would be helpful. Thank you !
    Feb 2009
    6028
    Re: K40 laser problems when turning on
    Check the belt and pulley. Can you slide the head easily by hand? Sounds like it's trying to reference.
    Hi underthetire, yes when the laser is turned off I can easily slide the head left and right. Can this be a hardware issue ? the way it's behave ? Should i replace the stepper ? Really don't know what to do
    Nov 2019
    Quote Originally Posted by iDaniel88 View Post
    Hi Daniel, i Ve your same problem, have you fixed It??? I really don t know how to do...
    Mar 2020
    I just got a k40 and when I turned it on my x axis goes up and does. It stop, I also can download the soft wear does anyone know anything about it? New to cnc and don’t know how to post my own question lol. Sorry
  1. Turning Toolpath Creation Problems
    By fidia in forum BobCad-Cam
    Last Post: 09-21-2015, 08:40 AM
  2. TC-2 problems with the spindle not turning on.
    By 72volvo145 in forum Fanuc
    Last Post: 01-22-2015, 03:18 AM
  3. Problems with my motors not turning smoothly
    By Andrew001 in forum DIY CNC Router Table Machines
    Last Post: 01-28-2014, 08:38 PM
  4. 4150 steel turning problems
    By lew52 in forum Material Machining Solutions
    Last Post: 09-21-2011, 01:32 AM
  5. thread turning problems
    By manraj_lotey in forum CNC Tooling
    Last Post: 07-01-2010, 04:49 PM
