586,628 active members*
2,586 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Live Tooling,,, grease leaking?
    Feb 2019
    38
    It's been a long haul but I finally got the T42 up and running. I've done some pretty basic parts and its holding super tight tolerances.
    I'm now starting to play with the live tooling. While drilling and tapping, I noticed some grease coming out of the live tools. Some more than others. I looked at the drawings of the live tools in my manual and it seems there are no seals in these tools to keep the grease in and/or coolant out.
    I noticed the live tools have a tag to grease daily. I think I've put two and two together here. I'm assuming the grease is indeed not sealed and should be greased daily to purge the innards of the tool of foreign debris. Much like the lube system on the ways of this machine. My thinking is this. If the tool was indeed sealed, the seal would become compromised if you greased it every day.
    I would love to hear your thoughts.
    Dec 2013
    5717
    Re: Live Tooling,,, grease leaking?
    Sounds just like mine. They leak a little grease. As they warm up, they leak a little more. I normally pump grease in until it starts to come out, then wipe it off and make parts.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2019
    38
    Thanks for confirming.
  1. Live tooling
    By mattlynx in forum Uncategorised MetalWorking Machines
    Last Post: 01-20-2014, 10:44 PM
  2. live tooling help
    By black powder in forum Esprit
    Last Post: 12-20-2011, 06:01 PM
  3. Replies: 2
    Last Post: 08-09-2010, 04:17 PM
  4. What is Live tooling versus "non-live tooling"?
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2007, 09:38 PM
  5. Need help with live tooling on cnc vtl
    By YV600 in forum G-Code Programing
    Last Post: 07-02-2007, 03:29 AM
