586,042 active members*
3,849 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Need Help to Drill
    Need Help to Drill
    Just starting to use new version of MadCam and Rhino 6.
    I want to drill some holes for some wooden bulkheads for my Kayak.
    I can generate the tool path and simulate.
    But when I post the G code an error message appears that it cannot find the cutter.
    The cutters and drills are in the library ( but the drills have a "drl" suffix?)
    Screen pictures attached.
    Any suggestions
    Thanks Terry
    Mar 2004
    1661
    Re: Need Help to Drill
    What happens if you change post processor, for example the linux cnc post?
    Feb 2018
    7
    In the picture Drill details.jpg i see there is no tool number.
    I can not check at this moment if this is the problem. But can you can try to give a tool number.
  1. How to drill a deep hole using U drill on floor boring machine
    By SatishNaik in forum News Announcements
    Last Post: 10-15-2013, 12:58 PM
  2. Replies: 47
    Last Post: 02-01-2008, 08:32 PM
