586,233 active members*
3,039 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Internal Carbide threading inserts for small threading tool (need advice)
    Mar 2016
    68
    Hi!
    I've got a cnc retrofitted mini mini lathe, with a mini QCTP and I plan to buy a 8mm thick indexable internal threading tool. This tool accepts 08 IR size inserts.
    I'm new to this indexable world, so I'm still learning. And my world is metric.
    So I'd like to do an imperial thread, 3/4 x 16 TPI. I'd like to know if these smaller inserts (08 IR) would allow me to do the job or if their cutting blades are too small.
    And as I'm in the metric world, could someone point me the right specifications so I could do this thread? Maybe one for metals and one for softer materials (aluminum). I imagined something like IR 08 AG55, but there are plenty of different variations and searching catalogs I got lost in shims, angles, etc.
    So, if not, if these inserts are too small for this, which size would be enough?
    Thanks for reading..
    Have a nice day!
    15362
    Re: Internal Carbide threading inserts for small threading tool (need advice)
    Quote Originally Posted by Rimbaldo View Post
    Hi!
    Have a nice day!
    Take a look at Carmex there are may to choose from this is one of the best Iscar and Carmex are both good in this area
    Mactec54
    Jan 2014
    126
    Small threads (yours is neither small nor large) are often done with a solid carbide ground threading tool. High end variants come from Micro 100, PH Horn, sandvik, etc. Most tooling manufacturers have a solid carbide boring/threading line. You can consider these for this application. Often they are much cheaper to buy into than an indexable tool.
    Something like this: https://www.carbideanddiamondtooling...Bore.Series.30
    Just an option
  1. Lathe threading inserts
    By SBTM1 in forum Haas Lathes
    Last Post: 04-23-2018, 10:20 AM
  2. offset for internal threading tool on siemens 840d SI
    By moriocka in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-21-2018, 08:37 AM
  3. Threading Inserts
    By boydage in forum CNC Tooling
    Last Post: 02-05-2015, 04:49 AM
  4. Internal threading tool suggestions
    By kdoney in forum Mini Lathe
    Last Post: 04-04-2013, 11:46 PM
  5. Small single-point internal threading
    By SweetJustice in forum MetalWork Discussion
    Last Post: 10-24-2010, 03:58 AM
