Hey all,
I was wondering how does someone using mc8 stop program and start it(not using m01) when size is correct?.
I wnat to finish a diameter but leave .5 to check size then once checked maybe push start?? and program continues.
Hey all,
insert an M00 in the appropriate place in the program
www.integratedmechanical.ca
You can setup your post so when you do a "Manually entry" between operations ,your machine will move to its home position and post out a M00, and a comment you added in your "Manual entry"
G53 Z0.
M00 (Check tap drill)
S5000 M03
M08
