586,061 active members*
4,637 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Live tooling on Okuma LB25 IIM
    Oct 2018
    Does anyone use live tooling on their lathe for profiling?
    I can't get the finish anywhere near decent enough.
    I'm wondering if the vdi held live tooling isn't designed for this application and was more suited to drilling, tapping and reaming in the z as the rigidity may not be there.
    For information I used a short indexible cutter with varying depths of cut, speeds and feeds on an aluminium billet.
    Feb 2009
    6028
    Re: Live tooling on Okuma LB25 IIM
    Should leave a reasonable finish, hows the turret alignment? If it's off, the milling drive system may not be lined up causing some binding.
    Oct 2018
    Quote Originally Posted by underthetire View Post
    Alignment is good. I'm just thinking that the bearings in the tool is worn. I might need to get it opened up and checked out.
  1. Help okuma lb25 osp7000L
    By Motiejunas in forum Okuma
    Last Post: 10-23-2016, 07:24 AM
  2. Okuma lb25
    By Enzoeng in forum Okuma
    Last Post: 10-12-2016, 02:59 PM
  3. Replies: 6
    Last Post: 02-06-2014, 04:05 AM
  4. Okuma Capitan Live tooling Question
    By bman356 in forum Okuma
    Last Post: 09-04-2012, 09:47 PM
  5. Okuma LC20 With Milling/Live Tooling ???
    By davtbarber in forum Okuma
    Last Post: 02-22-2008, 09:01 PM
