586,385 active members*
3,414 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Need Help. Machine not cutthing to size, Tool Offsets ???
Results 1 to 6 of 6
    Aug 2004
    210
    Hello there
    I am having a hard time with my machine, it been cutting around 0.030" under size,
    I double checked the x and y axes and backlash with my dial indicator and everything is pretty much perfect.
    I made code using Inventor and Aspire also did one by hand to cut a simple 2"x2" square and they all end up pretty much the same, 0.030"-0.035" under size
    Is there setting in Mach that has something to do with this ??
    I made sure the tools table offset are all set to zero
    Any one have any ideas ???
    Dec 2008
    3111
    Re: Need Help. Machine not cutthing to size, Tool Offsets ???
    1st things 1st.... is your machine moving the correct distance ?
    ie mark at X0,Y0 move 10" in X and measure... do the same for Y
    if correct then look to your program... what strategy do you program to ?
    ie is the toolpath the actual finish profile of your job ?.... tool offset cannot be = zero. it should be either the tool radius or tool diameter.
    If toolpath is offset from the part profile by the tool radius, then tool offset is theoretically = zero
    .... but you must use the tool diameter as programmed
    .... if you use a tool smaller than programmed the a -ive value is placed in the appropriate offset number. To make the tool pass closer to your work shape.
    .... if you use a larger tool, a +ive number is used... but this opens a field of problems, most common being the cutter cannot process an internal radius smaller then the tool being used.
    what tool size did you use ?
    ... guessing it was a 1/16"
    ... if you use the part profile method, then the offset should have been 0.0315
    put up your nc code for the 2" square
    Aug 2004
    210
    Hi There
    Yap i double checked everything on the machine and everything is good
    I am using 1/4" cutter
    I tried something simple like this
    G01 X2.25
    G01 Y2.25
    G01 X0.0
    G01 Y0.0
    and using Aspire or Inventor i get the same results
    i posted the code Aspire did
    Attached Files Attached Files
    Try doing a climb cut, and measuring the size. It'll probably be larger.
    Dec 2008
    3111
    Quote Originally Posted by Biggermens View Post
    Hi There
    G01 X2.25
    G01 Y2.25
    G01 X0.0
    G01 Y0.0
    well... it's not tool offest values...
    your program is not using G41 D1 or G42 D1, nor has a G40 to cancel cutter comp.
    D1 being the stored value you put in for the amount of compensation...
    CAUTION.... some controls have only 1 field per offset number. don't make the mistake of calling a tool length instead of a radial offset
    Your discrepancy must come from a different reason... Gerry is suggesting flexing through the tool or spindle
    Are your tools reasonably sharp ?
    Aug 2004
    210
    I feel a bit stupid but i found the problem, my machine is a pile of junk, it flexes everywhere if i take light cuts then my parts are to size.
    now i have to figure out how to make this thing stronger hehe
    Thanks everyone
  1. Replies: 2
    Last Post: 10-24-2014, 04:17 PM
  2. Tool Offsets, Part Zero, Machine Zero, X, Z, U, W, on a Fanuc 6T
    By mflux_gamblej in forum MetalWork Discussion
    Last Post: 03-05-2013, 04:18 AM
  3. MX2000ST Tool Offsets / Machine Options
    By H234 in forum Daewoo/Doosan
    Last Post: 06-01-2012, 08:42 AM
  4. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
