587,507 active members*
2,657 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > fadal will not power up
Page 1 of 2 12
Results 1 to 20 of 29
    Mar 2011
    273
    I had this problem when I first received it and replaced the power supply with a new one, and never had any major problems, maybe once in a while it would give me trouble, not not often.....until today. I go to power up the machine and all is good, go to cold start the machine and it said clear the e-stop (low on lube) then powered it down since it would not clear the e-stop. Go to restart and it does the weak sound where there is power in the back cabinet but does not power up like it should. I can hear ticking, open up the cabinet and the glentek p/n 4558-303 model ga380-2050 has a green light, BUT the red light keeps doing a faint red flash, and that is where the ticking is coming from. When I push the green button I get a relay that makes a real buzzing sound from below the transformer, and has a red light and the machine will not power up. I have attached the picture of the 4558-303 component and the relay in question. I would love if someone can get me going again
    edit: when it does this the work light comes on, but dim, like it is not getting full voltage.
    Aug 2009
    1573
    Re: fadal will not power up
    Check Input Voltages to machine..Check Input Fuse's.... Fill Way Lube Tank....check Shop Air Pressure 90 min.
    What Year Fadal is machine an Model number?
    Mar 2011
    273
    It is a 93 vmc40, it is hooked up a phase perfect 10hp digital converter that is putting out 226v
    Aug 2009
    1573
    Quote Originally Posted by billsnogo View Post
    10HP Rating Converter is little small (I think) for 10HP Machine....now that converter is 2+years old...I would do more testing of your Input Power side of things, 1st
    Which Model is your Converter? so, others may know to comment on the problems you're having
    DJ
    Aug 2009
    1573
    Sounds like you're not getting 3 Phase power to the Fadal to me..next I would check your Phase Converter Outputs under load...Read the Manual for it to see how to check it...possibly.
    Next you could Turn OFF Power to everything!!!! wait 5 mins or so before Checking for possible loose Input Power Wires and to all DC Power Supplys maybe 1st..dont just look at them....use a tool to tighten them. Don't over tighten small ones
    Good luck,
    DJ
    Aug 2009
    1573
    Wow ...I was just reading about Phase Perfect converters here
    http://www.phasetechnologies.com/dow...ual%20V2.0.pdf
    Quoted from PP......"Replacement of the capacitors every three years is recommended. These capacitorssuppress electrical noise caused by the switching of the IGBTs. If they are degraded the electrical noise can damage equipment connected to the converter."
    How old is your Unit?
    Mar 2011
    273
    Time fly's by and my memory is so-so but believe it to be 2 years old. I bought it new and it has probably 300 hours on it.
    update, played with it a little this morning. The card with the red flickering light is in between the three power leads coming from the transformer for the spindle inverter and a heating element (not sure if that is what it is, but sure looks like a heating element) above the main cabinet. When I disconnect the three leads from the transformer the machine powers up just fine and sounds the best it ever has. Note that the spindle inverter has no error codes, so could the heating element be shorting out? This machine still has the old mazatrol fz300 spindle inverter. I sure hope it is not the inverter that is the problem....
    Aug 2009
    1573
    That heating element looking thing is a Regen Resistor part of the Spindle Drive Braking system.
    Here's the Fadal 4020 Spindle manual.....Which Drive do you have? Should be a Fadal Number INV-xxxx on it.
    https://flintmachine.com/images/uplo..._and_Motor.pdf
    Mar 2011
    273
    Mine is not listed in the manual you posted, mine must be older. It is a freqrol z300
    Mar 2011
    273
    Converter is phase perfect pt-330, inverter is freqrol z300. Phase perfect specs says unlike a rotary phase converter you don't need to double the hp to have it run.
    Aug 2009
    1573
    The 3PH Convertor Phase Perfect PT330 is only rated 36Amps max output
    quote from manual above .....7.For models with three-phase output, the input wire gauge must be sized to accommodate the single-phase input current, which will be approximately 1.8 times the total three-phase output current to the load(s). For example, if the output load is 20 HP, the three-phase output current will be approximately 54 amps, and the single-phase input current will be approximately97amps.
    ....I think your Fadal 4020 wants 50Amps input...
    Dec 2013
    5716
    If you disconnect power from the inverter and the machine powers up, then unfortunately I think you have found the problem. The inverter is dead or dieing. Disconnect the 3 power wires from the spindle inverter and try it again. If the machine powers up, you have found the problem. The ''heating element'' (regen resistor) is directly connected to the inverter.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    1573
    something to add JD's Post.....WITH POWER OFF to Machine....check with your Ohm meter (VOM) for shorts to ground on the VFD LineIN Terminals any reading of zero is a dead short
    Mar 2011
    273
    All three Inverter LineIN terminals show some resistance between them and ground. I checked incoming power again and all three lines are between 223 and 226 today. The varistor on the surge suppressor board that blew is connected to L2 which is also the main switch fuse that blew.
    anyone have another blown board that I can steel the varistor off of?
    Attached Thumbnails Attached Thumbnails fadal 1170 board.jpg   fadal 1170 board2.jpg
    Mar 2011
    273
    Just to update, I reseated several connections, and poof, two times I have powered up with no signs of problems. So either my inverter is on its way out and picking when it wants to work, or a connection was working its way loose. Lets hope for the latter. thanks guys!
    Feb 2007
    171
    Sir, I have a hard time believing the inverter can cause a boot up problem honestly. Hook up your inverter if not already and power up the machine. Press the green power button. If the machine will now power up, check the incoming voltage to the drive. You should get 230 VAC three phase to the drive. Don't spend time worrying about the PhasePerfect digital phase converter. They are simple to size. We are a dealer for them. Match the inverter HP to the spindle hp of your machine and you are good. No upsizing like the rotary cousin.
    If the voltage to the drive is good, check to be sure the regen resistors are not getting hot. That being said, let's check the low voltage power supply and make sure you have good voltage at all pins; 5, +/-12. If not, let's find out why. Check the secondary of your transformer and make sure you have the 120 needed for the amp chassis input and the 120VAC needed for the low voltage power supply. Check the output of your transformer that goes to the inverter. Let's make sure the voltage is good. It sounds like it is dead with the drive hooked up and okay when it is disconnected. I need you to double check this again and make sure you are making a good correlation between the inverter input voltage and your machine not booting. It doesn't add up.
    FadalCNC Tech Support
    Mar 2011
    273
    Quote Originally Posted by ASIGuy View Post
    Then I am not sure what would cause it. I finally was able to squeeze my probes for my good multi-meter in the square d box on the machine, and it show steady 227-229v between all three legs. I kept testing with my cheap meter and it looked fine until after 3 times testing it finally showed 400v fluctuating so I hooked up my good meter and it still ready just fine at 228v, SO it looks like all those other reading were bunk.
    So to update everyone on current situation so hopefully I can get some more great help.
    #1
    When this all started I would throw the knife switch on the box, and before I hit the green button I would hear ticking and see the red led flashing in unison on the glentek spindle external brake. When this happened it would not allow the machine to power up when hitting the green button. The light in the machine would be dim and the fans did not sound like they were up to full speed. This has happened on and off since I have had the machine, but usually it would work if I turned it on and off again.
    #2
    When I unhooked the three leads on the transformer going to the spindle inverter it would turn the light on the spindle brake green instead of red, the fans came up to full speed, and the light in the machine was at full brightness.
    #3
    I hooked up the the power to the spindle inverter again, tried turning it on and same as #1 happened again. Tried powering on and off and just would not come up.
    #4
    Checked to make sure all the wires at the spindle inverter, external brake, and transformer were solid, removed the fuse on the spindle brake and reinstalled.
    #5
    With the power to the spindle inverter still hooked up I powered it up and green light on the spindle inverter, fans at full speed, full light on work light in machine. I pushed the green button and the screen came on and it worked. I had THOUGHT everything had been fine but did not try to turn on the spindle.
    #6
    Tried the machine a couple days later so I could run some parts. Tried to warm up the machine but during Cold Start instead of saying just "a axis fault" (don't have my fourth hooked up) it stated c axis fault also, but it always just shoots that up while doing a CS and goes on. I gave it a spindle command and it faulted out. Spindle inverter had not power on. Checked for power on all three legs and the main fuse on L2 had blown.
    #7
    Hoping the fuse had been on it's way out and causing the issue I bought another, installed, and threw the switch. BANG! Flash came out the back on the rear cabinet. One of the Varistors on the surge suppressor board 1170 blew up, and that same fuse blew again. Now when power is applied NOTHING happens, maybe because of the surge suppressor blowing?
    #8
    checked power coming in with my cheap meter and kept getting weird readings leading me to think it was my phase converter. Today hooked up my good multimeter and power is just fine.
    Now what do I do for step #9? I am afraid to replace the fuse and surge suppressor just to have it blow again. Not cheap..... So how do I test at this point without just blowing things up?
    Do note that the power supply is less than a year old.
    Mar 2011
    273
    Yeah, I spoke too soon. When I posted it was fine, that was just to get it to power up, never tried to run it. Before I could not get the fans to get to speed, machine light was dim and could not get the controller to come up. Now I don't have that red flickering light on the external brake for the spindle, but now my spindle will not power on. I can home my machine, and jog my axis, but will get a c fault when doing a spindle command. Inverter does not look like it is powering on when I look at it in back. There is a light on, but it did that also when I tried to run it on single phase when I first got it.
    edit:
    checked power at the inverter:
    10v 237v 229v
    power coming in to switch
    226v
    330v
    430v(weird, even more so since the PP states 225/226/227v)
    after the fuses
    10v 227v 227v
    Pulled the middle fuses and ohmed each one and sure enough, one is open. Guess it is time for a new fuse.....
    Aug 2009
    1573
    Looks like you're going VFD Shopping....I saw this while looking around for your Mits freqrol z300 manual
    https://www.automationdirect.com/adc..._vac)/gs3-2015
    Price looks great but, get what you pay for sometimes and must Interface to your Fadal what ever you buy.
    or maybe "The Rock"
    https://www.fadalcnc.com/index.php/inv-0096.html
    But..its priceee
    Mar 2011
    273
    Waaaaaa! I installed the new fuse, threw the switch and POP! So depressed, I had really hoped it was just a bad fuse. I wish I had setup video so I could see exactly where the spark came from, it looked to be on right side of the transformer where there is a reset switch where the three L lines connect. I checked and the same fuse popped. L2 must have a short on it somewhere and I do not know the next best step. I don't want something dangerous and I don't want to keep buying these expensive fuses, so anyone have some good diagnostic step to start at?
Page 1 of 2 12
  1. Fadal VMC 15 won't power up after power outage
    By RMMachine13 in forum Fadal
    Last Post: 01-28-2020, 07:32 PM
  2. Fadal will not power on
    By lukemckenzie in forum Fadal
    Last Post: 10-19-2017, 10:25 PM
  3. need wiring schematic for fadal power supply
    By billsnogo in forum Fadal
    Last Post: 04-08-2017, 04:05 AM
  4. Fadal power supply upgrade?
    By mnmattie in forum Fadal
    Last Post: 01-20-2017, 02:19 AM
  5. Fadal VMC4020HT slow to power ON - Help!
    By emexcee380 in forum Fadal
    Last Post: 12-01-2014, 09:47 PM
